soaking injector nozzles in white spirits overnight?
Would white spirits clean diesel crud off injectors tips at all? I have heard of people using bbq cleaner soaking the tips overnight but I only have spirits but don't want to damage them. Thanks in advance.
Try and scrape or pick off as much as you can with a flatblade then soak it in coca cola
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
Whatever u do don't scrape over the tiny tiny little holes it will be enough to open them up or damage them. They are ridiculously small holes so won't take a lot to damage
Cheers guys, these are my old ones going back on as the new ones were crap. I just fancied cleaning them up as much as possible before hand.
I can't seem to get the nozzles off at all! Fricken welded on. Also I don't have any coke cola lmao.
My soaking thing as to clean the insides really outsides are fine.
the insides will be reasonably clean
/Toseland
Yeah tbf I don't see the insides getting that dirty really. There isn't much that can get in and make them dirty.
Yeah, don't go physically scraping them with stuff, you're more likely to do harm than good.
Get the injectors on a wire wheel. When they've blown seals and leaked diesel all over the injector, i've wire wheeled the whole injector before and never had any problems
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
Doing the injector bodies should be fine, it's the nozzles you'll block up like that.
  Peugeot 306 HDi Not starting after sitting overnight CaptainHair 10 17,975 26-11-2024, 02:03 PM
Last Post: Beb
  Upgraded hdi nozzles with correct firing angle. mechsman 25 15,516 22-09-2015, 01:53 PM
Last Post: Poodle
  Upgrade nozzles for HDi jammapic 21 15,416 06-09-2014, 01:18 PM
Last Post: tb205gti
