  • 1 Vote(s) - 5 Average
BOSCH VE GUIDES - Pump setup and fine tuning
Guide: Bosch pump setup and tuning
Before you go fiddling with your Bosch fuel pump its a good idea to read this guide and understand what the main parts of the pump do, why you would want to change them and what effects changing them will have on your engine. Most of the information in this guide can be found from other sources on the web but im hoping to have the bulk of the important stuff all here together, making it easier to read and learn about the pump.
Firstly, make yourself familiar with the main parts of the pump and understand what does what while your driving. See the photos below for a general guide.
[Image: edit1.png]
[Image: boschmaxfuel.png]
[Image: boschedit1.png]
[Image: edit2.jpg]
Now you where everything is and whats its for youâ??ll want to know how to adjust certain things and understand what adjusting them does. Below are numbered sections with an explanation in each for specific adjustments.
1. Adjusting your idle
2. Adjusting the throttle arm
3. Adjusting the fuel screw
4. Adjusting the injection timing
5. LDA Modications
6. 11mm and gov-mod guide
1. Idle
The ideal hot idle would be between 800-900rpm and cold idle between 1000/1100rpm. If you locate the hot and cold idle screws you should be able to see a pivoting arm between the two of them and a cable attached to this, which goes to the wax stat. The wax stat will pull the cable in when the engine temperature is low and this will then pull the pivoting arm to the right (You should be able to move the arm from left to right with your fingers when the engine is hot).
When the pivoting arm is not under tension (Hot engine) it will rest to the left. If you look at how the arm operates you will see it has 2 prongs which rest on the bottom of either the left or right idle screws. When hot it rests against the screw on the right and when cold it rests against the screw on the left. By winding these screws in or out we can change the resting point of the arm and therefore the idle.
Hot idle adjustment - Left hand side screw, slacken the 10mm locknut and wind the screw in (clockwise) to increase the idle speed and out (anti-clockwise) to lower the idle speed. Once correct speed is achieved re-tighten locknut.
Cold idle adjustment â?? Right hand side screw, slacken the 10mm locknut and wind the screw in (clockwise) to lower the idle speed and out (anti-clockwise) to increase the idle speed. Once correct speed is achieved re-tighten locknut.
Also, remember that you can adjust the cold idle speed even when the engine is hot by pushing the pivoting arm to the right and holding it there while you adjust the screw.
2. Throttle arm
The throttle arm is connected to the throttle cable (and that connected to the accelerator pedal) and also the throttle shaft. When the cable is pulled the arm rotates and twists the throttle shaft, which in turn moves the governor shaft and leverset inside the pump and increases the fuelling/engine speed. The throttle arm rests at idle on a screw found at the back of the pump and at full throttle it rotates anti-clockwise until it reaches the max travel limit screw on the front of the pump.
The throttle rest screw can be adjusted by slackening the 10mm locknut and winding in to raise engine speed, or wound out to reduce engine speed. This should only be used to reduce the idle when you cannot get the idle low enough by adjusting the idle screws. Past a certain point it will not reduce engine speed any more. At this point, you could remove the throttle arm from the throttle shaft (Explained in detail in the gov-mod guide) and move the throttle arm anti-clockwise 1 spline on the splined shaft. However this will mean you will lose 1 spline of throttle arm travel at maximum throttle. Some people would chose to combat this by grinding the part of the throttle arm that touches the throttle rest (Will let the arm sit further back) or grinding the other end of the throttle arm which touches the max throttle stop, to gain back the throttle arm travel lost when rotating the arm on the shaft. Both of these are fine to do as long as you are careful and donâ??t get silly with the grinding.
The max travel limit screw is usually just removed when tuning the pump to let the engine rev a little higher and inject slightly more fuel. If you remove the throttle stop screw the throttle arm will just contact the pump body at full throttle. You can grind off the part of the throttle arm that touches the pump body for slightly more arm travel.
3. Fuel screw
The fuel screw (Located on the right side of the pump) controls the injection length. By turning this screw in you will increase the length of time the pump injects fuel per stroke, and thus end up with more fuel, or smoke. Increasing the injection length will cause the fuel to burn at a hotter temperature and means you get less efficient combustion.
However, it is the simplest way of increasing the fuel and as long as you donâ??t go mad it wont have a noticeable impact on efficiency. At a certain point, usually after turning it in around 6 full turns from stock, it will cause the idle to rise to ~3000rpm. When this happens the fuelling limit for a â??stockâ?? pump is almost reached. You will need to turn the fuel screw back out marginally until the idle drops back down and claw back a little extra fuel elsewhere. The only other simple mod you can do to increasing fuelling from here is an LDA rotate/grind.
4. Timing adjustment
The pumps timing is controlled by the cambelt and controls when the fuel is injected. You can adjust the pumps timing slightly without removing or even touching the cambelt, but instead by loosening the bolts that hold the pump to the pump bracket and rotating the pump back or forwards. The bolts that hold the pump to the bracket are shown as best as possible in the below photos:
[Image: edit3.png]
[Image: boschbracket.jpg]
There are 3 bolts on the left, one at the front of the pump, one at the back of the pump and one under the pump. (The pump bracket photo helps you see where on the bracket the bolts are located) The top 2 are easy enough to get to but to reach the bottom one you may need to remove the alternator or cut a 13mm spanner in half, it can be quite fiddly. The one on the right is at the bottom under/behind the 4 metal injector lines. In the photo abovve you cannot actually see the bottom 2 bolts, but the arrows indicate where they are located. You also cannot see the rear left bolt, but it is easy enough to see when you look.
You may also want to slacken the 4 17mm union nuts on the metal injector lines (at the pump end, NOT the injector ends) as these sometimes make rotating the pump hard. Once all bolts are slackened, you should be able to hold the top of the pump and push/pull it into position. As a general rule the pump usually runs best between 2/3rds and ¾â??s ADVANCED, but you may need to adjust it a bit more/less depending on your engine. It is also possible to adjust the timing while the engine is running, but make sure you are holding the pump steady while somebody else starts the engine and do not let go of the pump until the bracket bolts are tightened up again.
Note, many people do not bother to tighten the bottom left bolt back up, so that any future adjustments donâ??t involve having to struggle at loosening it again. From my own experience I donâ??t see any problem leaving it loose or removing it as long at the other 3 bolts are tight. However you do this at your own risk.
5. LDA Modifications
Please see my seperate guide for LDA tuning here - BOSCH VE GUIDES - LDA modifications.
And also see Londondan's guide for 11mm and gov-mod here - BOSCH VE GUIDES - 11mm Hybrid Bosch Pump + Gov Mod
Very good write up there dan lots of information on offer Smile
Bye Bye D-Turbo
Nice one Dan,
Some good info there.
[Image: sigi-2.png]
great guide a question though in the third pic mine has the ufo damper missing is it needed? as most of the bosch pump pics dont seem to have any fitted? what purpose does it serve if fitted?
vincent1 Wrote:great guide a question though in the third pic mine has the ufo damper missing is it needed? what purpose does it serve if fitted?
if stops the revs dropping off so quickly if you let off the gas, hence stopping jerky engine braking . . . .it's not essential just makes for a smoother drive . . .Smile
cool cheers matt
very useful indeed - any chance in chucking in an LDA section?? Smile
Thanks everyone. Ginge, the LDA is a fair bit more in-depth imo so I gave it its own thread/guide, found here Big Grin
ginge191 Wrote:very useful indeed - any chance in chucking in an LDA section?? Smile
If Dan doesn't then I will do one later that he can add Smile
Team Orange Engine Bay
cheers!
only that my friend's offroad land rover (raised with snorkely and the usual offroading gear) has a bosch standard, slightly different to the pugs, and has a fairly differnt set up - he wants it 'tuned' to get a bit more torque.... Smile
Did both of you miss my post above?! lol
Dan! Wrote:Did both of you miss my post above?! lol
oh :oops:
lovely jubbly - in that case - as a suggestion, perhaps link the LDA thread just under the max fuel section to carry it on, that would be lovely Smile
Yeah, good suggestion, cheers mate Smile Will add it in now.
I swear that wasn't there when I replied :roll:
OK I won't bother then, but yeah they are a bit more involved, I would stick a link at the bottom of your first post in this thread linking to the LDA one for anyone working through!
Edit:- FFS beaten by ginge with the same idea Sad tell you what, I will get my coat...........
mark_airey Wrote:FFS beaten by ginge with the same idea Sad tell you what, I will get my coat...........
:clap:
Links added to my LDA thread and also Londondans 11mm and gov-mod thread Big Grin
Great minds or something like that anyway eh ginge............lol
Dan! Wrote:Links added to my LDA thread and also Londondans 11mm and gov-mod thread Big Grin
Can I suggest also adding links as like a 5 & 6 here?
"1. Adjusting your idle
5. For LDA adjustments see here..
6. For 11 pump guide see here..
Just to make them a bit easier to find for our more "special" members who don't look like me and ginge lol
For you Mark, yes I can do that :romance-inlove:
can i make a further suggestion,
adding in the end
CREDITS TO: ______ :roll:
Took a minute to realize one of them pumps is mine Smile
Just lol to all the above conversation!
Great write up Dan!
HDi Cabby Project Click
What if your stupid and have a phase 1 406 pump.....
D@wson Wrote:What if your stupid and have a phase 1 406 pump.....
Dont look on a 306 forum for the answers?! :roll:
Fitted on a 306.... semi electronic.
Another noobish bit of input; which way do you have to rotate the pump to advance/retard it? (I assume you push the top towards the head to advance, but having trouble getting my brain around it right now..?)
Yep, top of the pump towards the cabin advances the timing/injection, and moving the top of the pump towards the slam panel will retard it.
Poodle Wrote:Another noobish bit of input; which way do you have to rotate the pump to advance/retard it? (I assume you push the top towards the head to advance, but having trouble getting my brain around it right now..?)
That's correct, engine runs clockwise remeber, so your pushing the pump "into" the timing.
[Image: sigi-2.png]
Awesome, ta. Big Grin
Thought this seemed relevant copied from this thread: <!-- l --><a class="postlink-local" href="http://www.306oc.co.uk/forum/viewtopic.php?f=12&t=3028" onclick="window.open(this.href);return false;">viewtopic.php?f=12&t=3028</a><!-- l -->
[Image: DSCF1804.jpg]
[Image: DSCF1805.jpg]
[Image: DSCF1807.jpg]
1. Lucas fuel feed banjo, already connected to fuel line on car, Bosch banjo is on the pump
Just remove banjo and put pipe onto the bosch fuel inlet just next to that in the photo
2. Fuel run off line, connects to where?
Connect it to 13 in the other photo (return to tank) you may need a longer bit of leakoff pipe though...
3. Throttle cable arm, which of the two small holes should the cable connect to?
Connect to the one the bolt isnt in, and id slide the whole plastic thing in on the slot on the throttle arm towards the pump all the way.
4. Boost compensator, connects to T-piece on FMIC setup (and presumably the line my boost gauge plumbs into?
Correct
5. Throttle cable guide
Correct, when pump is at idle position, set clip so cable is just tight, but not taking any strain
6.
Fuel out from filter (heading for pump inlet banjo on left side of pump underneath throttle arm)
7. Some kind of vacuum line, goes where?
This is your vacume pump, connect it to the brake master cylinder
8.
This is an air bleed line for the coolant system, there should be a pipe kicking about somewhere in that area with a bleed hole in it that connects to there... same pipe goes to fitting behind pump on the head and also top of the rad / expansion tank
9. Another vacuum line, again goes where?
Normally vac feed for EGR etc...just bung it with a screw.
10. One way breather valve, goes to where on FMIC cars?
Oil breather, either connect back into the air intake (pre turbo) or to a catch tank etc
11.
LDA breather / vent, nothing connects here, just so pressure can equalize under the diaphram
12.
Pump fuel return feed, returns fuel to tank via the other fuel line.
13.
As already said, connects to injector leak off pipes.
14. Stop solenoid? Needs ignition live and earth connected to plug at lower part of pump?
Only needs ignition live, its just a single wire on top the solenoid, god knows why pug routed two cables... The solenoid earths itself to the pump / engine
Credits to cwspellowe for pictures and MrLobb for the write up
Cheers Ginge, very useful stuff. Credit to Darren for a detailed run-down Smile
  Guides Section Index Scott 7 35,249 04-10-2018, 01:01 PM
Last Post: balkan_bozo
  Multiple Youtube Guides for Pug306 timpug 3 5,611 12-06-2015, 11:15 PM
Last Post: 7057sam
  Guide: Easy to watch video on increasing fuel on the bosch pump sammyb303 7 6,989 03-06-2015, 05:44 PM
Last Post: Pug0BZ3011
