checkered roof plan
so im planning on checkering the roof, need to decide which stuff to get
do i get a whole sheet 1.5m x 1.5m
http://www.carwrapdirect.com/chequered-f...-with-adt/
or do i get 30 separate stickers
http://www.ebay.ie/itm/CHEQUERED-ROOF-GR...35e99df933
[Image: 13073041_458228241037318_1249062425_o_zpsoh6qf7gu.jpg]
Whole sheet I reckon, be impossible to line up 30 stickers tbh!
(15-05-2015, 09:16 PM)Toms306 Wrote: Whole sheet I reckon, be impossible to line up 30 stickers tbh!
i was thinking the same but then with the hole sheet getting bubbles out. is it like tinting a window? never done any wrap before
I sense an epic fail...
Trust me that squares on wrap material would be difficult for an expert to fit right. Separate squares will mean the paint fading differently, but what you want is separate squares on application tape (good vinyl, oracal or avery 7 year minimum) and then you'll have a chance to measure and get it right.
Make sure the aerial is not in a square too, end the sides under the door rubber and into the guttering
PS I used to run my own sign company Wink
P1 XSi track car
2.4 LWB T4
I was gonna say the 30 individual squares as if you f*ck one up you can always replace that one square and it's cheaper. It will need careful application but such is life.
The only problem with the 30 squares is they might well not be enough, look at the pic they use in the ebay listing, how many squares did they use, 35 right? not 30.
Or just don't do it...?
Is there any reason other than looks that you want to do it? i.e roof rust, bird shite etc.
I mean each to their own, sorry if this has come across arsey, i really don't mean it like that but your car looks nice as it is Wink ThumbsUp
I reckon you want a large vinyl sheet with all the individual squares on transfer tape. You will never line up ten squares let alone 30. The full sheet I reckon is possible....
  This is ONLY a plan JethroJay 31 17,582 01-03-2014, 12:29 AM
Last Post: WiNgNuTz
