Cylinder head faced 0.33mm removed
I have just collected the cylinder head from the machine shop!!
The pressure test was good, they vacuum tested the valves as I freshly ground them back in to there seats and that was all fine.
They skimmed the cylinder head and took 0.33mm off the face, I do not know what the tolerances are for using the started head gasket (which I have already bought). Can somebody advise whether I should be good with a standard head gasket without the valves touching the pistons? Huh
The engine is a XU10J4 from a 1994 306 S16
Thanks!
they have big valve cutouts so should be ok but there id a repair gasket available.
Thanks for the reply, I'm in two minds just to give the gasket i've got a try.
But just in case I need it in the future where is the best place to get the repair gasket without paying main dealer prices?
Thanks
Main dealer gaskets are cheap, the OE Gti6 one is cheaper than any crappy pattern one and they fit correctly which again most pattern ones don't
But fit a std gasket, it will be fine, loads of room as the pistons come no where near the top of the block so upping the compression won;t do any harm
  GTI6 cylinder head cully 9 5,817 24-10-2015, 08:19 PM
Last Post: thododd
  Tube found in intake port of cylinder head lpr1981 23 13,998 19-04-2015, 11:11 PM
Last Post: welshpug
  Cylinder head rebuilt, but now sounds like a diesel, please help! rj.stead 6 4,176 14-12-2014, 12:17 PM
Last Post: Dum-Dum
