Anyone used 2-stroke oil in a HDI?
(24-04-2015, 05:00 PM)JTaylor2005 Wrote: Dunno why the ash thing matters that much really. Presume its just to stop dpf's and cats etc clogging up. I just used whatever the stuff in my garage was haha. Gonna see how it goes
Can't remember, but it wasn't a trivial reason like that.
Back when i had my HDI i used a few bottles of 2 stroke on it, as others said it seemed to smooth it out Smile
This is a must do ?
No mate, this is down to the owner. Wink
There seems to be loads of positives for adding 2 stroke in your tank, you just have to make the decision yourself. I personally would do it and I am going to soon Wink
Used to do it with the last xud, bit of extra lube for the pump can't hurt to my mind Smile
Its supposed to lower emissions, increase mpg (marginally), lube injectors and pump leading to quieter running...the list goes on. Im thinking of getting a box of Stihl-Saw shots to chuck in Big Grin
http://www.lsengineers.co.uk/stihl-2-str...100ml.html, bit pricey really but I know a guy there Wink
http://www.lsengineers.co.uk/stihl-hp-su...100ml.html ash free this stuff is, but high price.
Thats the stuff i have been putting in mine for ages now its all been good, my injectors were really noisey before i started using it and i have noticed a difference they are quieter.
I have put my first lot (200ml) into a full tank of diesel about 5 days ago after reading up and i don't know if its just me or placebo effect but it definitely sounds smoother under load! either way I am very happy.
What I used: http://www.ebay.co.uk/itm/1x-Comma-Two-W...35e4393c38
I take it yous keep putting it in every week then or whenever you fill the tank?
(06-05-2015, 01:51 AM)Deangatt Wrote: I take it yous keep putting it in every week then or whenever you fill the tank?
This is the first tank I have put it in mate but from what I have read from the guys on here that use it you do have to do it every tank. Its not to bad for me I only use about 2 tanks a month.
Thanks given by: Deangatt
#41
Think it's time I started to do it aswell going to get a bottle an fill her up at the weekend
Good man! I am happy with how mine runs with it. Smile
Im tempted to give this a try. Does it make much difference using mineral or semi synthetic?
I read semi, but heard others saying mineral does the same...?
Heard mineral burns better cus it's basically just thicker diesel haha
Wink each to their own Big Grin
semi lmao!!!..... that was made as it dont oil spark plugs so bad as mineral dont think you will have that issue on a diesel
the main thing to look for is the low ash! basicly so it burns with no ash residue to clog rings and other stuff
GTI6 Info
I thought semi synth was low ash? Or most of them anyway?
I'm using Mineral low ash stuff Smile
What are the effects of using more than 300ml/tank? Curious
Any brands/deals that anyone can recommend? Gonna try it in my next tank as well...
(08-05-2015, 04:07 PM)Iceman299 Wrote: What are the effects of using more than 300ml/tank? Curious
waste money and cause's smoke
GTI6 Info
Just gambled on a £4 bottle of low ash mineral oil whilst in Focus DIY. Only had about a 1/3rd tank left, so chucked in about 100ml, but it is a bit difficult to put in the filler straight from the bottle. It did have noticeable results though, less smoke, less injector rattle and hell of a lot more perkiness!
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
use a coca cola bottle the end fits into the filler nice and if you fill the bottle to the lower label line its around 210ml
[attachment=23041]
GTI6 Info
Drink vast quantities of the 2 stroke oil and then piss down the filler hole.
You member = natures petrol pump
[Image: mcetg0.png]
(08-05-2015, 05:00 PM)cully Wrote: use a coca cola bottle the end fits into the filler nice and if you fill the bottle to the lower label line its around 210ml
Now i have to go out and spend £1 on a bottle of coke lol
Yeah but it's only a one time buy so the cost will spread out over the time ur using 2 - stroke oil
go bin diving close to your local takeaway Tongue
GTI6 Info
(08-05-2015, 06:12 PM)JTaylor2005 Wrote: Yeah but it's only a one time buy so the cost will spread out over the time ur using 2 - stroke oil
I was just messing around mate lol
Good idea. Might find a half eaten kebab if i'm lucky to compensate for calories burnt
Great news as its smoothed your engine out Big Grin
as i said i used it in my old HDI
And use it in my current XUD as i run wvo from work and want to add a little more lubricity for the bosch pump Smile
