Anyone used 2-stroke oil in a HDI?
05-05-2015, 12:24 AM
Back when i had my HDI i used a few bottles of 2 stroke on it, as others said it seemed to smooth it out
05-05-2015, 03:28 AM
This is a must do ?
05-05-2015, 08:29 AM
No mate, this is down to the owner.
There seems to be loads of positives for adding 2 stroke in your tank, you just have to make the decision yourself. I personally would do it and I am going to soon Stage 1 HDi DTurbo Diablo 5dr, "Dee-Dee"
05-05-2015, 08:36 AM
Used to do it with the last xud, bit of extra lube for the pump can't hurt to my mind
05-05-2015, 08:47 AM
(This post was last modified: 05-05-2015, 09:00 AM by highwayman306.)
Its supposed to lower emissions, increase mpg (marginally), lube injectors and pump leading to quieter running...the list goes on. Im thinking of getting a box of Stihl-Saw shots to chuck in
http://www.lsengineers.co.uk/stihl-2-str...100ml.html, bit pricey really but I know a guy there http://www.lsengineers.co.uk/stihl-hp-su...100ml.html ash free this stuff is, but high price. Stage 1 HDi DTurbo Diablo 5dr, "Dee-Dee"
05-05-2015, 11:01 AM
Thats the stuff i have been putting in mine for ages now its all been good, my injectors were really noisey before i started using it and i have noticed a difference they are quieter.
06-05-2015, 01:14 AM
I have put my first lot (200ml) into a full tank of diesel about 5 days ago after reading up and i don't know if its just me or placebo effect but it definitely sounds smoother under load! either way I am very happy.
What I used: http://www.ebay.co.uk/itm/1x-Comma-Two-W...35e4393c38
06-05-2015, 01:51 AM
I take it yous keep putting it in every week then or whenever you fill the tank?
06-05-2015, 02:16 AM
(06-05-2015, 01:51 AM)Deangatt Wrote: I take it yous keep putting it in every week then or whenever you fill the tank? This is the first tank I have put it in mate but from what I have read from the guys on here that use it you do have to do it every tank. Its not to bad for me I only use about 2 tanks a month. Thanks given by: Deangatt
06-05-2015, 02:18 AM
Think it's time I started to do it aswell going to get a bottle an fill her up at the weekend
06-05-2015, 02:21 AM
Good man! I am happy with how mine runs with it.
07-05-2015, 12:31 PM
Im tempted to give this a try. Does it make much difference using mineral or semi synthetic?
07-05-2015, 12:57 PM
I read semi, but heard others saying mineral does the same...?
07-05-2015, 02:03 PM
Heard mineral burns better cus it's basically just thicker diesel haha
View my build thread here
http://306oc.co.uk/forum/showthread.php?tid=28072
07-05-2015, 04:34 PM
semi lmao!!!..... that was made as it dont oil spark plugs so bad as mineral dont think you will have that issue on a diesel
the main thing to look for is the low ash! basicly so it burns with no ash residue to clog rings and other stuff https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
07-05-2015, 06:26 PM
I thought semi synth was low ash? Or most of them anyway?
08-05-2015, 10:52 AM
I'm using Mineral low ash stuff
08-05-2015, 04:07 PM
What are the effects of using more than 300ml/tank? Curious
08-05-2015, 04:12 PM
Any brands/deals that anyone can recommend? Gonna try it in my next tank as well...
08-05-2015, 04:25 PM
(08-05-2015, 04:07 PM)Iceman299 Wrote: What are the effects of using more than 300ml/tank? Curious waste money and cause's smoke https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
08-05-2015, 04:38 PM
Just gambled on a £4 bottle of low ash mineral oil whilst in Focus DIY. Only had about a 1/3rd tank left, so chucked in about 100ml, but it is a bit difficult to put in the filler straight from the bottle. It did have noticeable results though, less smoke, less injector rattle and hell of a lot more perkiness!
2001 BMW 330Ci
2012 VW High Up 1988 205 GTi 1.6 1990 205 Mi16
08-05-2015, 05:00 PM
use a coca cola bottle the end fits into the filler nice and if you fill the bottle to the lower label line its around 210ml
[attachment=23041] https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
08-05-2015, 05:27 PM
Drink vast quantities of the 2 stroke oil and then piss down the filler hole.
You member = natures petrol pump
08-05-2015, 05:29 PM
08-05-2015, 06:12 PM
Yeah but it's only a one time buy so the cost will spread out over the time ur using 2 - stroke oil
08-05-2015, 07:27 PM
(08-05-2015, 05:29 PM)Iceman299 Wrote:(08-05-2015, 05:00 PM)cully Wrote: use a coca cola bottle the end fits into the filler nice and if you fill the bottle to the lower label line its around 210ml go bin diving close to your local takeaway https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
08-05-2015, 07:32 PM
(08-05-2015, 06:12 PM)JTaylor2005 Wrote: Yeah but it's only a one time buy so the cost will spread out over the time ur using 2 - stroke oilI was just messing around mate lol (08-05-2015, 07:27 PM)cully Wrote:(08-05-2015, 05:29 PM)Iceman299 Wrote:go bin diving close to your local takeaway(08-05-2015, 05:00 PM)cully Wrote: use a coca cola bottle the end fits into the filler nice and if you fill the bottle to the lower label line its around 210mlNow i have to go out and spend £1 on a bottle of coke lol Good idea. Might find a half eaten kebab if i'm lucky to compensate for calories burnt
08-05-2015, 08:14 PM
Great news as its smoothed your engine out
as i said i used it in my old HDI And use it in my current XUD as i run wvo from work and want to add a little more lubricity for the bosch pump |
