Threads: 13
Car Model/Spec: 306 S16
After stripping the bumper, slam panel, lights, radiator etc from the front of my S16 I have discovered some chassis damage!!
The cross-member is badly damaged and the N/S chassis leg has a slight bend in it causing buckling of the top panel where the ABS pump is sat.
Has anybody here ever had a chassis leg repaired or replaced? I assume it is a guaranteed MOT failure due to it being dangerous.
What should I do now? Help
Threads: 371
29
Car Model/Spec: ford fiesta
It wont be a Garenteed fail. Ive had a fiesta front end completely cut off and an entire side welded in by a body shop. Wasn't mine was a friends. It is possible just expensive.
Threads: 34
8
How good are you at welding? Easy fix if you're good with metal work tbh
Threads: 34
8
Scrap car.. Best bet is go to a scrappy and cut off well past the damage, preferably right back to a join, drill spot welds out and put new one on
Threads: 92
43
I've had a leg pulled out straight
306ocĀ Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam
Threads: 13
Sounds like a plan, it would be a shame to scrap it there is not many S16's about now.
Threads: 371
29
I was gonna say deffo fix it. Not worth it going to scrap yard. Getting rare as you said.
Threads: 34
8
Btw i wasnt saying ti scrap yours.. I meant get a leg from a scrapped car lol
Threads: 42
28
how bent is it? my zx was pretty bent lookung but I managed to straighten it out with a mate, porta power jack and big and all hammers
Threads: 13
After further investigation and removing a couple of the panels from the very front of the car I think I can straighten the leg with a reasonable hammer and a piece of wood. Most of the damage is definitely around cross-member and the panels that it is spot welded too. I have managed to source 80% of these panels for a very good price and they are genuine but am unable to get a cross-member, once I have removed it from the car it looks like I can straighten it. The only thing that concerns me is going from the two panels I have removed so far the metal seems really soft and possibly brittle and it may not be up to much straightening as it will probably make it weak, I guess it was designed this way so it absorbs most of an impact (which it did). If it breaks I will find a scrap yard for a donor!
Threads: 208
60
I bent a chassis leg on a Dt some years ago it was 1" lower & 2" wider than it should of been. I put a big bar in the front of the leg and bent ot back into place. There was an obvious crease on the side of the leg down the side of the cambelt casing and it happly passed a couple of legit MOTs like that.
Threads: 13
10-04-2015, 05:33 AM
(This post was last modified: 10-04-2015, 05:33 AM by lpr1981.)
WOW! Thanks for the pics, a definite insight into what I am up against and when compared to the bend that your GTI 6 had it is not that bad.
I would not call your repair a bodge, you used the tools you had along with your ingenuity. Brilliant!!
Threads: 206
Car Model/Spec: 3dr dt-s
in work we have huge steel bolllards to stop cars reversing into walls (about 12" in diameter)-----I wrap a chain around the bollard---attach to point B on your car and then reverse the car away !!! pulled out several cars that turned out ok.
