Speedo dip/ Power loss
Just had something weird happen. Driving at a steady 40 and there felt like there was a very slight loss of power, I glanced down and just caught the speedo needle dipping to zero and back again.
Looming crank sensor issue? I have no manual to see where the speedo gets it's signal from.
Earth connections to chassis from the engine at a guess, that's a classic for making the speedo go funny - the speedo is driven off the diff, rather than anything to do with the crank sensor.
Thanks given by: Shawnobi
Its your speedo sensor on the gearbox failing.
(20-03-2015, 02:29 PM)"HDi--Power Wrote: Its your speedo sensor on the gearbox failing.
Happend to me, new sensor and the problem never came back
As above speedo sensor, mine used to do the same.
Just to echo the above, its your VSS. Quite a common fault and not that expensive to sort Smile
  Intermittent Loss of Power Alan_M 2 4,398 17-02-2020, 04:40 PM
Last Post: Charlie0
  Loss of power steering etc mattbarker32 5 3,521 10-03-2016, 02:54 PM
Last Post: Poodle
  occasional momentery loss of power pug306driver 11 6,261 16-11-2015, 08:52 PM
Last Post: steve1001
