Axle time
Axle time
Right done some 106 and 206 axle rebuild before and there is lots differences in bars stubs arb etc
My guess is the gti 6 has best arb etc so would like to rebuild that ideally
Mine has been lowered and got some play I see they are build kinda opposite off 106 206 sub in arm not beam. So my q is can they get that bad that i can't fix even if I buy new stubs and bearings as my mate doing a 205 one and looks like it was starting to eat in to beam
Thanks
yeah, same as the 205 if the bearings go that badly that the shaft wears through the tube brackets then they're toast, its not hard to find a decent donor crossmember though.
Thanks given by: xudlingo
(17-03-2015, 06:29 PM)welshpug Wrote: yeah, same as the 205 if the bearings go that badly that the shaft wears through the tube brackets then they're toast, its not hard to find a decent donor crossmember though.
Don't thank that bad seen worse fingers crossed
