Axle time - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Axle time (/showthread.php?tid=29745) |
Axle time - xudlingo - 17-03-2015 Right done some 106 and 206 axle rebuild before and there is lots differences in bars stubs arb etc My guess is the gti 6 has best arb etc so would like to rebuild that ideally Mine has been lowered and got some play I see they are build kinda opposite off 106 206 sub in arm not beam. So my q is can they get that bad that i can't fix even if I buy new stubs and bearings as my mate doing a 205 one and looks like it was starting to eat in to beam Thanks RE: Axle time - welshpug - 17-03-2015 yeah, same as the 205 if the bearings go that badly that the shaft wears through the tube brackets then they're toast, its not hard to find a decent donor crossmember though. RE: Axle time - xudlingo - 17-03-2015 (17-03-2015, 06:29 PM)welshpug Wrote: yeah, same as the 205 if the bearings go that badly that the shaft wears through the tube brackets then they're toast, its not hard to find a decent donor crossmember though. Don't thank that bad seen worse fingers crossed |
