Since i recently found out my XUD advertised car is really just a DW8 with intake and exhaust manifolds from an XUD i started thinking about the possibility of swapping over the intake manifold from the DW8.. the long,pretty unrestricted runners would that ideally align pretty well with a Front-mounted inter cooler being the main reason.. anyone think this is possible?
DW8 intake mani on an XUD?
13-03-2015, 07:27 PM
I would think there would be too much pressure in there really.
It is designed to only take air in, not hold it, under boost conditions of a fair few PSI. My opinion anyway. ![]() I Don't Have A 306.
13-03-2015, 08:46 PM
i thought about doing this at one point. cant see why it wouldnt hold some pressure. worth a hot if you have have one lying about
13-03-2015, 08:51 PM
They're plastic from memory, no reason why not, but if you feed it silly levels of boost you will split the manifold along it's seams... I think it's only ultrasonic'd together around the edges, not designed to take large amounts of boost!
13-03-2015, 11:18 PM
(13-03-2015, 08:51 PM)Ruan Wrote: They're plastic from memory, no reason why not, but if you feed it silly levels of boost you will split the manifold along it's seams... I think it's only ultrasonic'd together around the edges, not designed to take large amounts of boost! Wasnt early n/a metal mani? Same style though
14-03-2015, 03:32 PM
Early NA manis are steel, but have the really shitty seal design half way down the runners like the 2.1 - recipe for boost leaks!
| Relocation Mani Query | silverzx | 4 | 4,032 |
02-05-2015, 09:00 PM Last Post: Lolben91 |
| inlet mani studs | philpemberton94 | 9 | 5,051 |
13-08-2014, 01:40 PM Last Post: Dave |
Identify this Inlet Mani ! | andyyy | 12 | 6,900 |
07-03-2014, 05:07 AM Last Post: Dave |
![[Image: 2ljm03k.jpg]](http://i57.tinypic.com/2ljm03k.jpg)
