Relocation Mani Query
People going above or below this? I'm gonna try go over, then there is plenty of space for exhaust to run back down?
[Image: IMG_4027.jpg]
Maybe grind off the flange and weld a 90* bend to the water pipe?
(17-04-2015, 12:39 PM)Dum-Dum Wrote: Maybe grind off the flange and weld a 90* bend to the water pipe?
Or grind it back an inch or two, put an inch of pipe on, with a hard 90 coming out. Idea
People going above or below this is the question at hand though. Wink
I've gone below on the ones I've done for Tom mate. Just keep it tight to the block and there is room for a 3" turbo exit pipe, on a ZX anyway :-)
Dum Dums idea is easy enough tho, that water pipe is weldable but it's thin and rusty.
I went under, but then found the gear links made contact, its quite a tight bit of space there
  Turbo query / help 2.1 Cbray2003 6 5,353 04-12-2017, 06:34 PM
Last Post: Piggy
  Turbo relocation 306pc 9 7,392 26-02-2017, 11:58 PM
Last Post: Dave
  DW8 intake mani on an XUD? 089 5 5,113 14-03-2015, 03:32 PM
Last Post: Ruan
