Threads: 145
5
11-03-2015, 10:31 AM
(This post was last modified: 11-03-2015, 10:48 AM by pug306driver.)
egr blanking.....yes I understand that not much "muck" will be recirculated if this devise is blanked off.....and the vacuum actuator disconnected...but is there feed back to the ecu that the ecu will compensate for the lack of egr.......and use more fuel??
also will low eng temp cause the ecu to fuel enrich??
Threads: 591
54
no.
and yes. But only till engine is warm!
Threads: 145
5
thanks for the prompt reply.....ours seem to sit at 70 degrees when hot but goes up when eng is worked harder like going up a long hill ( we live in a hilly area and it rains a lot ) .............it doesn't seem to get warm enough in my opinion.....thermostate was checked some time ago and seem to work normally, opening and closing and opening at the right temp ish.....fans seem to work ok ( low speed seem to cut in at 100 ish and cut out at 90 ish ) but are never heard when driving. we don't tend to get long traffic jams here even in summer .....
Threads: 117
119
That sounds an awful lot like a thermostat issue. When you checked it was it done properly with a thermometer? Should open at 83 degrees centigrade iirc.
Threads: 91
83
'Enrichment' doesn't quite work like that on a diesel...
The ECU compensates for the engine requiring more fuel to operate at low temperature, but this is merely to make the engine run and idle... It's not like a spark ignition engine where the AFR is adjusted and causes it to run smoother when cold...
Diesels have no 'throttle' remember, if you 'enrich' the mixture... You make more power and the engine revs go up. The injection angle is adjusted however and this does affect consumption..
However a cold running engine is not good for efficiency... As stated above, sounds like a thermostat issue.
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in.
Threads: 186
6
Car Model/Spec: Peugeot 306 2.0 HDI
Im going to go out for a drive in mine in a bit and see what mine gets up to on a decent drive. Im not convinced mine is getting up as high as most cars reach atm tbf.
Threads: 117
119
11-03-2015, 09:34 PM
(This post was last modified: 11-03-2015, 09:35 PM by Poodle.)
That's nearer 80, shouldn't be a problem, a healthy HDi will typically run at a steady 78-80.
