EGR Blanking
EGR Blanking.
I know there is plenty of forums about it but I have 2 questions
the standard egr blanking plates on ebay? do they just go in the inlet elbow? Huh
if the egr is blanked at the inlet does the plug/vac pipe need to be pulled? and if the pipe is pulled does it need plugged? Huh
W Reg 2000 HDI for reference .
The plate goes between the inlet elbow and the egr pipe, if it's blocked physically you don't need to unplug it but can if you want, you unplug the electrical connector as opposed to the vacuum hose though. If you did pull the hose off you'd need to block it with something or you'd have a vacuum leak
  egr blanking pug306driver 7 3,850 11-03-2015, 09:34 PM
  egr blanking? JTaylor2005 4 2,965 21-02-2015, 06:48 PM
Last Post: shervo
  EGR blanking off? 306estate2.0HDi 20 8,178 07-12-2014, 06:12 PM
Last Post: tuttyboy84
