11-02-2015, 12:19 AM
Surely you have to keep to minimum weights though...
P1 XSi track car
2.4 LWB T4
2.4 LWB T4
306 rallye trackday project
P1 XSi track car
2.4 LWB T4
11-02-2015, 10:09 AM
12-02-2015, 07:21 PM
bonded lexan rear screen in carbon rear hatch skin ,ready for fitting
13-02-2015, 07:53 PM
bourght this as will be adding throttle bodies ,will be making mould and making carbon fibre copies
13-02-2015, 08:22 PM
Mine is sitting at about 990kg at the moment but it has a much bigger cage and only a fg bonnet.
Not too fussed about getting it much lighter, mostly because it's going to get expensive (except shrinking my sizeable arse). At the moment I'm moving weight backwards and inside the wheelbase. What fun! Definitely a car to follow
P1 XSi track car
2.4 LWB T4
14-02-2015, 05:08 PM
(13-02-2015, 08:22 PM)adam b Wrote: Mine is sitting at about 990kg at the moment but it has a much bigger cage and only a fg bonnet.
16-02-2015, 07:12 PM
fitted rear hatch over weekend on original hinges so will still open mega weight saving
17-02-2015, 11:51 AM
Wow, this is just stunning!
17-02-2015, 02:04 PM
18-02-2015, 01:10 AM
The cossie's epic mate
Must make the 306 feel pretty boring ?? Astor 6 Fast road/track project
18-02-2015, 09:36 AM
19-02-2015, 09:17 AM
fitted carbon bonnet skin, works on original hinges so no need for 4 bonnet pins , just fitted front recessed bonnet pins and started flatting ready for painting ,another great weight saving
19-02-2015, 03:15 PM
I wish I had the skills and knowledge to make carbon and fiberglass parts. Nice work mate.
19-02-2015, 03:31 PM
19-02-2015, 09:02 PM
started to trial fit carbon door on drivers side and have laid passenger side outer skin ,so will remove tomorrow and bond to inner skin ,and hopefully have both fitted over weekend depending on weather
24-02-2015, 02:00 PM
carbon fibre front panel , was done a while back and fitted , have got to super fine and laquer ,with a load of other bit I have made , eg rear carbon spoiler phase 2
24-02-2015, 06:59 PM
Very good to meet you yesterday
![]() Shame I couldn't have stopped longer for more of a chat!
P1 XSi track car
2.4 LWB T4
24-02-2015, 07:13 PM
25-02-2015, 07:43 PM
sorry for lack of progress due to sh**ty weather but going threw photo's and came across this what I did to car , good weight saving and stops getting dnf on rally's was to mount wiring socket on bulkhead , due to Peugeot's crappy idea of running along front and first thing you hit ends up blowing wiring , there is a good weight saving by doing this and well out of harms way ,sorry for crappy picture as was when first done
05-03-2015, 07:26 PM
haven't had much chance to do much on car lately due to weather and other commitments , but got too it today and fitted discs and bells that had lying round from when had cosworth , 1kilo lighter than standard disc per side unsprung weight , and 25mm thickness , using standard calipers for now as pagid blues only done 1 track day ,so not letting them go to waste ,plenty of clearance on bottom joint
That looks great what size are they and does it change the pcd of the wheel so you have to run ford fitment wheels?
06-03-2015, 04:46 PM
18-03-2015, 04:08 PM
finished making carbon fibre rear spoiler ,and manage to clear laquer and also made carbon fibre cam cover , just got to trim were oil filler goes
18-03-2015, 04:14 PM
They look great,would ever make any spoilers up??
18-03-2015, 04:17 PM
18-03-2015, 09:49 PM
(18-03-2015, 04:17 PM)twangy Wrote:(18-03-2015, 04:14 PM)7057sam Wrote: They look great,would ever make any spoilers up?? Of course mate hope your recovery is going well Do you make moulds of everything you do so you can replicate it again?? Astor 6 Fast road/track project
(18-03-2015, 09:49 PM)7057sam Wrote:(18-03-2015, 04:17 PM)twangy Wrote:(18-03-2015, 04:14 PM)7057sam Wrote: They look great,would ever make any spoilers up?? yes sam , keep mould so can replicate most thing (18-03-2015, 09:50 PM)Piggy Wrote: Sweet work! cheers mate
11-05-2015, 09:19 PM
finally able to start weight bearing on leg ,so back on car ,have got paint for carbon panels and ,primed and painted rear hatch today ,so will fit and prep and paint another panel tomorrow , will add pictures this week of progress ,also made new carbon dash inserts
| Matts £200 Cherry Rallye shell rebuild & tidy up project. Xsara goodies landed! | Matt-Rallye | 70 | 63,690 |
07-03-2017, 12:58 PM Last Post: Matt-Rallye |
| Matts rallye project. operation derust | Matt | 630 | 480,332 |
23-06-2016, 06:41 PM Last Post: Frosty |
| The toy, 306GTI trackday racer. *Dial-up warning: Picture heavy* | Janne L | 142 | 88,173 |
11-03-2016, 07:58 AM Last Post: Janne L |
