2001 Hdi estate Fault codes
Car has been running okish feels down on power but it's the first hdi I have had so don't know the base
Anyway driving home from work early hours this morn and felt slight power drop and engine management light come on Confused had it to a mate is morn and on to pp200 and got the following codes need advice on them
Fault codes
p1521
p0401 maf
hi mate,
hope this helps if memory serves me well:
P1521 - Clutch Switch / Sensor
P0401 - EGR / MAF
have you tried unplugging the maf sensor and driving the car to see if it has less/ more / no difference in power?
thanks
P1521 is clutch sensor, the clutch peddle probably isn't returning to the top, usually because the self adjuster has jammed or gone to the end of its travel.
Faulty MAF will cause your power issue, but only replace with a genuine VDO unit. The cheap ones go faulty quickly. The EGR valve might also be leaking, best to blank it at the inlet elbow.
No haven't done anything with it at min and would be intrested in getting hold of a maf if anyone got a spare they willing to part with cheap and cash is rather tight till 15th :-(
And any ideas what to do to fix the clutch switch location and stuff ?
Cheers for the reply :-)
You could put a spacer between the clutch fork and cable end to take up some of the slack.
[Image: 74BC135D-D6AF-4A38-8F7C-C90C1613B9EB_zpsjxvgjxoh.jpg]
Is this the clutch switch :-)
Could be that or the brake light switch.
I think the clutch one is brown, but theyre pretty similar.
(01-02-2015, 01:58 PM)DeeTurbo Wrote: You could put a spacer between the clutch fork and cable end to take up some of the slack.
Only do this if you know the auto-adjuster is jammed, else it'll self-adjust to the wrong position. I'd have a look at losing the clutch pedal spring and stamp on the pedal a few times to encourage the self-adjuster to sort itself out first.
  Multiple HDI ECU error codes allye 16 8,770 29-06-2016, 04:01 AM
Last Post: Paul_13
  Fault Codes P0221 & P1521 Alan_M 4 4,791 17-09-2014, 01:06 PM
Last Post: mr_fish
  Fault codes hdi Hec1872 2 2,668 06-07-2014, 10:59 PM
Last Post: Hec1872
