01-02-2015, 05:17 PM
Offside driveshaft has gone, its it an easy/cheap job or is it a garage job?
Offside driveshaft
01-02-2015, 05:23 PM
Easy enough, intermediate bearing will be seized and need a big hammer though.
01-02-2015, 06:01 PM
Yeah any guides to removal on here? Search is useless on this app
01-02-2015, 06:14 PM
Jack up
Remove wheel Remove lower hub pinch bolt and nut (16&17mm) Pop hub off balljoint Remove hub nut (35mm, very tight) Pull hub towards you and shaft pops out For drivers side need to remove intermediate bearing (2 L shaped bolts with 11mm nuts need undoing) and hammer bearing out Make sure you either drain the gearbox or catch the fluid that comes out and then replace it afterwards.
01-02-2015, 06:25 PM
(01-02-2015, 06:14 PM)Toms306 Wrote: Jack upCheers, will give it ago, managed to find both shafts for £20 off a lad 10 mins away breaking his 5 door, I presume they will be the same?
01-02-2015, 06:35 PM
I think 1.4/1.6 shafts are smaller, but bigger engines are all interchangeable. Also if you have ABS, you will need ABS shafts.
01-02-2015, 07:43 PM
(This post was last modified: 01-02-2015, 07:43 PM by Davidwheaty.)
Don't think it has abs, haven't slammed on enough to notice though
And his is a 5door xud
01-02-2015, 07:49 PM
The driveshafts aren't distinguished by doors...
![]() Check for an ABS pump in front of the little fusebox. If not then yeah they'll fit fine.
01-02-2015, 08:39 PM
Will do, cheers lads
| Handbrake Offside | LewisG | 3 | 2,782 |
05-04-2014, 12:25 PM Last Post: LewisG |
