Clutch issuses
Hi guys, i'm a little confused.. i was always told that, as your clutch deteriorates the biting point rises.
but lately, if i pull away pretty sharply, my biting point seems to be lower!
any ideas what could be the issue???
Remove the clutch pedal damper/spring thing and see if that helps - they're notorious for causing issues like this.
If you look from the footwell up at the clutch pedal you'll see a plastic spring thing on the side - pop this off with a screwdriver and throw it in the bin!
Most 306's have auto-adjusting clutch cables so the biting point doesn't tend to change much as the clutch wears unlike older cars with conventional clutch cables.
Thanks, i'll give that a shot
Mine appears to bite when pedal gets close to floor. Bit difficult to get it into first a lot of the time but not consistently, sometimes it's fine!!! WTF , is this that spring thing behind the pedal playing up, or is my clutch or gearbox fooked? What's difference in symptoms 'tween clutch and gearbox probs?
J
Best to pop the spring off and see if it improves at all
