removing wingmirror caps without breaking clips???
Question
any tips peeps?? Spraying some up for the cherry, managed to get them off just breaking one clip but the wife binned one so need to remove another now, awkward little buggers aren't they? Tongue
Don't think I've ever got a pair off without breaking at least one clip lol. I just swap mirrors instead, only 3 bolts and no chance of breaking anything. lol
(08-01-2015, 09:14 AM)Toms306 Wrote: Don't think I've ever got a pair off without breaking at least one clip lol.  I just swap mirrors instead, only 3 bolts and no chance of breaking anything. lol
yeah but I need some colour coded lol... No worries, guess I did ok just breaking one then Smile
If you use a thin flat blade screwdriver you can push the glass round and just about access the clip to lever it back and release it. Still, breaking only one isn't bad going, they are a ballache lol
Don't do it when the plastic is very cold and brittle?
(08-01-2015, 09:43 AM)Jonny81191 Wrote: If you use a thin flat blade screwdriver you can push the glass round and just about access the clip to lever it back and release it. Still, breaking only one isn't bad going, they are a ballache lol
cheers good idea, I can see what you mean. I'll give it a go Smile
Warm em up ThumbsUp
Wait what? They have clips?
(08-01-2015, 02:55 PM)SRowell Wrote: Wait what? They have clips?
/\ This lol
Think the carbon skimmed ones where held on by super glue no more nails Smile
[Image: Cn91r40h.jpg]
I take the glass of gives you a bit more room to work at them.
(09-01-2015, 03:22 PM)ConorTRG Wrote: I take the glass of gives you a bit more room to work at them.
fook me didn't think of that either lol.....does it just pop off? Smile
Turn the glass as far to one side as possible, you've more access one particular way either fully left or right, I haven't done one in a while. And you'll see a wire clip. Pop it of then the mirror will come out.
(09-01-2015, 03:33 PM)ConorTRG Wrote: Turn the glass as far to one side as possible, you've more access one particular way either fully left or right, I haven't done one in a while. And you'll see a wire clip. Pop it of then the mirror will come out.
nice one fella, cheers Smile
[Image: impossibru-meme-sgb.jpg]
DUCT TAPE
[Image: Duct-tape-repair.jpg]
just done this thanks, it's actually really easy, you then put the wire back on the mirror and it clips back on with a firm push... Thanks again Smile
Good job, gives you alot more room to get at the clips ThumbsUp
Ph3's don't have those wire clips, just for anyone else trying to remove them. They just clip on and pull off... In theory lol
My ph3 has those wire clips Connor Undecided
I assumed you were at the stage of glass out matt!! But a bit of heat still helps to avoid snapping the clips ThumbsUp
(09-01-2015, 07:24 PM)doski Wrote: DUCT TAPE
I just don't understand people....why go to the time, effort and cost of a whole roll of duct tape when you could spend a tenner on a mirror and change it in 10 minutes! lol
(10-01-2015, 08:25 AM)Piggy Wrote: My ph3 has those wire clips Connor Undecided
nope, got the others out without touching the glass lol, you know what happens when you assume though? Tongue
clipping another car works for me but you got to stop and pick it up before it get run over!
GTI6 Info
  Door Card Clips Toms306 2 2,953 15-04-2016, 11:18 AM
Last Post: Toms306
  Heatshield clips Razorback_Rob 6 5,108 13-09-2014, 08:20 PM
Last Post: Toms306
  HDI engine cover clips Whodafunk 14 7,326 26-12-2013, 04:08 PM
Last Post: mcglynn
