205 Hdi
#91
Fitment wise yes.
Use exactly the same mounting points on all three mounts.
Swap the lever over on the gearbox and you use the 205 gear linkages.
He should of just used a gti subframe
#92
(04-01-2015, 07:34 PM)Paul_13 Wrote: Fitment wise yes.
what about the electrical side of things? i can see why diesel geek used the 306 full car loom for more plug and play electrical wise.
#93
engine loom would be easyaly doable with an unlocked ecu
would be almost the same as grafting a gti6 loom in the 205
GTI6 Info
#94
is there much info on this type of conversion?
#95
loads on google just search
http://205gtishop.moonfruit.com/gti-6-co...4570113521
GTI6 Info
#96
With the lack of response from OP I can only assume he took the car for a test drive.
#97
Ha maybe
It would be very similar to a 6 loom conversion on a 205
#98
indeed, I've seen two conversions before, one was into a Laser green gti, using gti shafts and subframe.
as mentioned, wiring wise it will be exactly like doing any other engine management conversion into the 205, no need to touch the dashboard whatsoever.
#99
Big Grin
(04-01-2015, 08:54 PM)cheesegrater Wrote: With the lack of response from OP I can only assume he took the car for a test drive.
Big Grin
(04-01-2015, 07:22 PM)Piggy Wrote: @mattcheese. Obviously be impossible to prove anything on forums like this...but the principle applies.
haha you blow my mind mate, if you were a troll you'd be amazing Big Grin
(04-01-2015, 08:01 PM)cully Wrote: loads on google just search
I have to say the information is miles better, than the vvc or 1.8 k series turbo conversion in a metro. As people are very tight lipped with the wiring side of things, and that's just for starters!
If I were to do an engine conversion into another car again, I will be wanting to see a one done and up and running again.
I have a funny feeling OP won't be seen again, has gone 'hidden' so is probably hiding with embarrassment.
(05-01-2015, 04:29 PM)JJ0063 Wrote: I have a funny feeling OP won't be seen again, has gone 'hidden' so is probably hiding with embarrassment.
I am not surprised, he has gone hidden.
