Threads: 2
hi there new to the form and looking for a bit off help
got a 2.0 hid estate and it has a stage one map the now and de cat ...the clutch is starting to slip so i am looking for a bit off help on whats the best one to go to upgrade .as i am going to buy intercooler and get stage to map on it thanks guys
http://306oc.co.uk/forum/images/smilies/huh.png
Threads: 110
20
How much power/torque are you aiming for? Get a new decent make standard clutch and as long as driven with some sense it should hold it
Threads: 2
kl this is good to no i wow told it is about 125bhp the now
If you're going stage 2 a standard clutch probably won't be good enough. A couple of people have gotten away with it, but the vast majority have found it's not up to the job. Helix or Sachs paddle clutches are generally considered the best options for the money, dual-friction is supposed to be better and more drivable, but they're a fair bit more expensive.
Threads: 110
20
I think the helix clutchs new are around the £450 mark
