Threads: 136
I have been asked by an eBayer if I'd package up my Rallye seats for a courier. Front seats won't be a problem but I think the rear bench will be too wide for a pallet. Is anyone able to measure a bench for me please? Mine are 50miles away...
Are they not split 70/30 in Rallyes? I'll measure mine tomorrow if no-one else has.
Threads: 0
45
Can't you put the rear bench upright against the seats?
Paisley freight will courier a full interior for £59.99 if not.
Threads: 87
48
(15-12-2014, 04:20 PM)Toms306 Wrote: Are they not split 70/30 in Rallyes? I'll measure mine tomorrow if no-one else has.
no . . . . .
Ah, fair enough. Tbh I'm surprised they even fitted rear seats, think of all the weight they could've saved!
Threads: 136
15-12-2014, 05:07 PM
(This post was last modified: 15-12-2014, 05:08 PM by Ben.)
Unfortunately not, all part of the weight saving! Cheers Tom
(15-12-2014, 04:21 PM)JJ0063 Wrote: Can't you put the rear bench upright against the seats?
Was thinking they might then be too high, which is why I wanted the measurement. Need to get the guy to find out what dimensions are allowed with his courier. If not I'll suggest Paisley, thanks for that.
Threads: 541
124
Surely it would of been easier to just go out and measure it?
Threads: 465
114
Car Model/Spec: Vauxhall
Lmao @ DumDum
(15-12-2014, 04:02 PM)Ben Wrote: I have been asked by an eBayer if I'd blah blah skim reading fail much chris?? Is anyone able to measure a bench for me please? Mine are 50miles away...
(15-12-2014, 05:59 PM)Dum-Dum Wrote: Surely it would of been easier to just go out and measure it?
Threads: 541
124
(15-12-2014, 06:25 PM)cully Wrote: Lmao @ DumDum
Yep, I am aware of that but we are now 2 hours later and he still doesn't have a measurement and there is no sign that one is coming. In 2 hours he could of driven and done it
Threads: 465
114
they must be the same size as the std 70/30 splits just lighter ?
15-12-2014, 06:43 PM
(This post was last modified: 15-12-2014, 06:44 PM by Toms306.)
And wasted a tenner of fuel...  Plus he's probably doing something important like work or watching tv atm...
Edit - I assume theyre the same width as 3dr seats combined, as said I'll check mine but it wont be this evening lol.
Threads: 541
124
(This post was last modified: 15-12-2014, 07:09 PM by Dum-Dum.
Edit Reason: Measurements added.
Yeah they do weigh f*ck all when you flip the base up you can feel the difference whereas the meridian split leathers would drop with a thud the rallye base kinda floats down.
(15-12-2014, 06:43 PM)Toms306 Wrote: He's probably doing something important like watching tv atm...
When is watching transvestite arse-to-mouth porn important?
EDIT:
So I've hopped out and measured it for you and its 130cm wide
Surprisingly it weighs 7.78kg but both bits of the lower half of a GTi6 beam only weigh 7.54kg between them. I suspect I might need to put the dehumidifier in the car.
Threads: 136
(15-12-2014, 06:44 PM)Dum-Dum Wrote: Yeah they do weigh f*ck all when you flip the base up you can feel the difference whereas the meridian split leathers would drop with a thud the rallye base kinda floats down.
Whenever the need arises.
EDIT:
Thanks very much, not quite as wide as I thought they'd be. Wonder if I could get a wide enough pallet...
Yes if those weights are accurate then something's up, or Peugeot really cocked up! Maybe the rallye seats need a really good hoover!
Threads: 541
124
15-12-2014, 08:35 PM
(This post was last modified: 15-12-2014, 08:36 PM by Dum-Dum.)
You can get double wide pallets, there is some kicking around by me outside the pub.
Personally I'd stand them up on their ends/sides as I assume you are going to stack the seats in a L7 position on the pallet so they would stand beside.
(15-12-2014, 06:44 PM)Dum-Dum Wrote: (15-12-2014, 06:43 PM)Toms306 Wrote: He's probably doing something important like watching tv atm...
Each to their own I guess!
Threads: 136
That's good to know. I'll have a search at work and see if I can find any.
Threads: 25
Car Model/Spec: Vectra & Berlingo
Given 5 thank(s) in 5 post(s)
How far are they going? Sometimes cheaper to get a van to collect via Shiply. Pallet delivery is between £40 - £75.
Threads: 136
One of the guys is in Scotland so a few hundred miles. Not sure where the other is. Don't know if I've got time to package them anyway, if no one wants to collect them I might wait til the new year to sell.
