2.2 hdi injectors
2.2 hdi injectors
Has anyone used the 2.2 injectors in the 2.0 engine?
(22-11-2014, 06:12 PM)sherman306 Wrote: Has anyone used the 2.2 injectors in the 2.0 engine?
No you cant use them. JTD nozzles are a good upgrade.
I didn't think so just someone on fb saying he's put them in and got a good power gain
The dw12 injectors are totally different to dw10
Different age of engine, newer technology
Well if its on FB...must be true!?
lmao
2.2 4Hx injector have longer body and different locking system on the head. But you can use the 2.2 nozzles on RHY injector body, but angle and plane angle will be wrong, and they flow only a bit more
(22-11-2014, 08:10 PM)ozonehostile Wrote: The dw12 injectors are totally different to dw10
Errrr.... They're not at all!
They're just a different layout - absolutely identical mechanism.
Where can you get those JTD injector nozzles from??
www.darwendiesels.com/
Firad do a version of them which will be cheaper than Bosch.
