2.2 hdi injectors - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: 2.2 hdi injectors (/showthread.php?tid=27895) |
2.2 hdi injectors - sherman306 - 22-11-2014 Has anyone used the 2.2 injectors in the 2.0 engine? RE: 2.2 hdi injectors - Uberderv - 22-11-2014 (22-11-2014, 06:12 PM)sherman306 Wrote: Has anyone used the 2.2 injectors in the 2.0 engine? No you cant use them. JTD nozzles are a good upgrade. RE: 2.2 hdi injectors - sherman306 - 22-11-2014 I didn't think so just someone on fb saying he's put them in and got a good power gain RE: 2.2 hdi injectors - ozonehostile - 22-11-2014 The dw12 injectors are totally different to dw10 Different age of engine, newer technology RE: 2.2 hdi injectors - Piggy - 22-11-2014 Well if its on FB...must be true!? RE: 2.2 hdi injectors - dashmader - 23-11-2014 2.2 4Hx injector have longer body and different locking system on the head. But you can use the 2.2 nozzles on RHY injector body, but angle and plane angle will be wrong, and they flow only a bit more RE: 2.2 hdi injectors - Ruan - 23-11-2014 (22-11-2014, 08:10 PM)ozonehostile Wrote: The dw12 injectors are totally different to dw10 Errrr.... They're not at all! They're just a different layout - absolutely identical mechanism. RE: 2.2 hdi injectors - JTaylor2005 - 24-11-2014 Where can you get those JTD injector nozzles from?? RE: 2.2 hdi injectors - Uberderv - 24-11-2014 www.darwendiesels.com/ Firad do a version of them which will be cheaper than Bosch. |
