Threads: 3
Hello all. I'm currently planning my 205's 1.9 TD conversion and I'm fitting my VNT above the gearbox. I need to fabricate either a link pipe between the standard turbo manifold and new turbo or building a proper tubular manifold from the head to the turbo. I wondered what other people had done and if anyone could give me any idea of whether all the extra effort of building a tubular manifold would be worth it or not. Thanks.... Luke.
Threads: 6
Car Model/Spec: kingfisher Dturbo
on a old derv engine proper tube mani probably wont make much of a difference.. plenty of people running big power on a extention pipe from stock turbo manifold.
doenst mean dont do it tho! im planning to build one and ash on here is currently building one too
Threads: 142
11
Car Model/Spec: ph1 DT estate , 207 1.6 hdi
im currently playing with making a g/box mani tbh its not taken long up to now to actually mock the thing up was more time getting some flanges cit out literally just re started on it again today now i have the flanges.
is it going to be worth it? i dont care it will look cool
[attachment=20017]
[attachment=20018]
also have a spare set of flanges
[attachment=20019]
hope that helps ?
Car Model/Spec: 306 D Turbo
Mine. Full stainless with equal length runners
[attachment=20027]
(10-11-2014, 10:41 PM)londondan86 Wrote: Mine. Full stainless with equal length runners
Is that Darrens old one?
Threads: 26
[attachment=20028][attachment=20029][attachment=20030][attachment=20031][attachment=20032]
Simple lol hope this helps :-)
Threads: 24
Car Model/Spec: Cherry Red PH1 306 Dturbo
Threads: 90
(10-11-2014, 10:44 PM)Niall Wrote: (10-11-2014, 10:41 PM)londondan86 Wrote: Mine. Full stainless with equal length runners
Yes
Threads: 26
(11-11-2014, 01:46 AM)Owen_G_ Wrote: That looks epic paddy
Thanks lol did you get ur car fixed yet man
Threads: 14
Car Model/Spec: Vitara 1.9-xud9
11-11-2014, 11:19 AM
(This post was last modified: 11-11-2014, 11:22 AM by JamesPT.)
Threads: 143
10
Car Model/Spec: Ph3 XUD
Given 8 thank(s) in 8 post(s)
Is that ceramic coated!?
Can really see the restriction on the inner ports quite clearly there. If it were me, pair of flanges like ash has spare and a log manifold. Simple and very effective
(11-11-2014, 07:19 AM)darrenjlobb Wrote: (10-11-2014, 10:44 PM)Niall Wrote: (10-11-2014, 10:41 PM)londondan86 Wrote: Mine. Full stainless with equal length runners
Yes
Beat me to it!! Yea it is
Threads: 14
(11-11-2014, 03:46 PM)Piggy Wrote: Is that ceramic coated!?
Yes, thats Ceramic coated by Zircotec, and the Exhaust manifold was an issue, I wanted to do something better, but I can't move the turbo around at all like in a 306, must be right up next to the engine (Suzuki Vitara)... Maybe a real pro could of done it right. The stock manifold has the turbo Flange chamfered (Inside), and the ports are smoothed up a bit, and internally polished(somewhat).
Suzuki Santana Vitara 1.9 Td (Xud9) 3Dr
Threads: 41
Car Model/Spec: 306xrdt ph1
Given 4 thank(s) in 4 post(s)
(11-11-2014, 03:46 PM)Piggy Wrote: Can really see the restriction on the inner ports quite clearly there.
Whats the restriction like on the engine side? Worthy of a spot of porting ?
Threads: 3
Nice fabrications. Thanks for all your replies. Has anyone built a simpler two branch manifold and siamesed ports one with two, then three with four? This seems like an easier way to do it and you wouldn't have the hassle of trying to work out what order to weld everything up so you could get at all of the joints with the welder. The pipe from cylinders one and two could run pretty straight after it's first bend round to the right and cylinders three and four could wrap around this to try and equalise the lengths of these siamesed primaries. What do you all reckon? ...Luke.
I think unless your going to do a proper 4-1 then I'd be inclined to just weld a 3" bit of pipe straight to the existing manifold as has been done above.
Threads: 142
11
id say its got to be worth a bash at it. any thing has got to be better than the stock manifold.
Threads: 55
Car Model/Spec: D turbo 1.9
Threads: 202
58
Out of interest, what length oil lines are people using? As I need to get one made up for mine..
I think mine is about 1500mm but can't say I've actually measured.
Threads: 41
(11-11-2014, 03:46 PM)Piggy Wrote: pair of flanges like ash has spare and a log manifold.
Due to space I'm thinking a log manifold that would look a bit like a petrol intake manifold.
But looking at the flanges, at least one could do a couple of Y's and step up when the other pair join.
