406 hdi
406 hdi
Iv also got 406 hdi 2000 year can any1 help
I have a problem of the car cutting out when warm and when its on boost engine will cut out car starts fine n drives well
Clean the fuel pressure reg on the side of HP pump
[Image: av5ym8.jpg]
Hi thanks reply i have tried that also has in tank pump replaced it comes up with primary fuel pump fault
Sounds like the pump or regulator are past it then
[Image: av5ym8.jpg]
Best bet is to try a brand new regulator. I cleaned mine and it worked a bit and then died again. I bought one of the Bosch ones on ebay from Poland. Arrived next day!
Just make sure you get a new O-ring for the top of it (or reuse your old one - I did) since replacing It I have done 300 trouble free miles
