406 hdi - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: 406 hdi (/showthread.php?tid=27620) |
406 hdi - Dougieboy1 - 06-11-2014 Iv also got 406 hdi 2000 year can any1 help I have a problem of the car cutting out when warm and when its on boost engine will cut out car starts fine n drives well RE: 406 hdi - Jimbo - 06-11-2014 Clean the fuel pressure reg on the side of HP pump RE: 406 hdi - Dougieboy1 - 06-11-2014 Hi thanks reply i have tried that also has in tank pump replaced it comes up with primary fuel pump fault RE: 406 hdi - Jimbo - 06-11-2014 Sounds like the pump or regulator are past it then RE: 406 hdi - af1 - 06-11-2014 Best bet is to try a brand new regulator. I cleaned mine and it worked a bit and then died again. I bought one of the Bosch ones on ebay from Poland. Arrived next day! Just make sure you get a new O-ring for the top of it (or reuse your old one - I did) since replacing It I have done 300 trouble free miles |
