Fmic set up
Fmic set up
Would it be possible to create a fmic set up using longer sections of silicone hose?
[Image: 1FC08450-6AA6-42A5-84AD-4AFF7300DFDD_zpsiafkclxg.png][/URL]
It's got to be easier routing nice bendy bits and hard pipe in small sections when needed.
Never seen anyone do this though so I assume it's a bad idea?
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
It's not that bendy really, use it where you want, I wouldn't think it's a problem, not exactly cheap though Smile
Yeah lengths of silicone like that aren't all that bendy. They bend a bit then just kink.
Plus remember that when you come on boost, thats all going to try and straighten out. Hence why people use SS/Aluminium piping Smile
Personally if on a budget either:
A) Buy 2 meters of straight 2"/2.25" aluminium then figure out what silicone bends you need and buy them separately.
B) Buy a universal FMIC kit, use all of what you can then buy any little extra silicone bends that might help.
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
I bought 2 incomplete kits to make a whole. Laid it all out the other day and still thought I needed some more. It was just an idea. I didn't think about how it would move about when pushing 30psi through it. Maybe hard pipe is the answer.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Will a xantia fmic setup fit quite easily?
(29-10-2014, 01:16 PM)dt_ Wrote: Will a xantia fmic setup fit quite easily?
Jenks used parts of that setup
[Image: a7accc53.jpg]
pulled 175 odd on a t25 IIRC
