Fmic set up - Printable Version
+--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11)
+--- Thread: Fmic set up (/showthread.php?tid=27487)
Fmic set up - 306pc - 28-10-2014
Would it be possible to create a fmic set up using longer sections of silicone hose?
[Image: 1FC08450-6AA6-42A5-84AD-4AFF7300DFDD_zpsiafkclxg.png][/URL]
It's got to be easier routing nice bendy bits and hard pipe in small sections when needed.
Never seen anyone do this though so I assume it's a bad idea?
RE: Fmic set up - Mattcheese31 - 28-10-2014
It's not that bendy really, use it where you want, I wouldn't think it's a problem, not exactly cheap though Smile
RE: Fmic set up - Niall - 28-10-2014
Yeah lengths of silicone like that aren't all that bendy. They bend a bit then just kink.
RE: Fmic set up - Grant - 29-10-2014
Plus remember that when you come on boost, thats all going to try and straighten out. Hence why people use SS/Aluminium piping Smile
RE: Fmic set up - silverzx - 29-10-2014
Personally if on a budget either:
A) Buy 2 meters of straight 2"/2.25" aluminium then figure out what silicone bends you need and buy them separately.
B) Buy a universal FMIC kit, use all of what you can then buy any little extra silicone bends that might help.
RE: Fmic set up - 306pc - 29-10-2014
I bought 2 incomplete kits to make a whole. Laid it all out the other day and still thought I needed some more. It was just an idea. I didn't think about how it would move about when pushing 30psi through it. Maybe hard pipe is the answer.
RE: Fmic set up - dt_ - 29-10-2014
Will a xantia fmic setup fit quite easily?
RE: Fmic set up - mr_fish - 29-10-2014
(29-10-2014, 01:16 PM)dt_ Wrote: Will a xantia fmic setup fit quite easily?
Jenks used parts of that setup
[Image: a7accc53.jpg]
pulled 175 odd on a t25 IIRC
