25-09-2014, 10:05 PM
Anyone done this? Worth doing?
Xsara VTS Steering Rack on HDI
25-09-2014, 10:13 PM
Suppose to be a quick rack, worse than the gti6. But can be done.
25-09-2014, 10:14 PM
Well worth it but make sure you get a rack from a PH1 VTS. The PH2 is .2 of a turn more...doesnt sound a lot but does make a difference!
So i tell the missus anyway
ment to essentially be a quick rack no? depending how many less turns to turns it is id say it deffo worth it
25-09-2014, 10:24 PM
Thanks lads, would it make the steering heavier and put more strain on the components and tyres due to the VTS having higher gearing and a different turn to turn?
25-09-2014, 10:28 PM
Phase 1 VTS rack will go straight on. To fit a Phase 2 VTS, you'll need the PAS pipes too as they're unique to the rack.
I have one of each in my garage, plus the 2.4 manual rack on the 205. I would've fitted the Ph2 rack to my 306 during the overhaul but I lent the pipes to Paul_13 for his 205 and I'm not sure I can be arsed to fit it now.
2001 BMW 330Ci
2012 VW High Up 1988 205 GTi 1.6 1990 205 Mi16
25-09-2014, 10:37 PM
(25-09-2014, 10:24 PM)MY95 Wrote: Thanks lads, would it make the steering heavier and put more strain on the components and tyres due to the VTS having higher gearing and a different turn to turn? shouldnt imagine it would change the heaviness of the steering atall just quicker steering its a mod im planning on doing
26-09-2014, 06:02 AM
If you're fitting them on a hdi you'll be able to get the pipes off a late xsara hdi, same fitment apparently.
What I'm planning on doing with a ph2 Vts rack on the hdi. Do you want me to get you a set of those pipes Alan?
26-09-2014, 08:38 AM
(26-09-2014, 06:02 AM)Paul_13 Wrote: If you're fitting them on a hdi you'll be able to get the pipes off a late xsara hdi, same fitment apparently. If you can (and if they are the same), but there's absolutely no rush. As I said, I can't be arsed to fanny about with the HDi now, the 205 is begging to be worked on (that's getting the Ph1 VTS rack and electric pump setup).
2001 BMW 330Ci
26-09-2014, 08:44 AM
(26-09-2014, 08:38 AM)Alan_M Wrote: ...the 205 is begging to be worked on Christ alive, I never thought that I'd see the day!
26-09-2014, 01:29 PM
(26-09-2014, 08:44 AM)powerandtorque Wrote:(26-09-2014, 08:38 AM)Alan_M Wrote: ...the 205 is begging to be worked on Shut it, beatnik
2001 BMW 330Ci
27-09-2014, 07:36 AM
Quick rack ftw
306 Rallye giving people a surprise because they think shes a 1.6 ;-) Silly people
| Power steering rack.....replacement options | Jellomanpie | 9 | 9,477 |
30-04-2020, 05:54 PM Last Post: Mighty306 |
| 306 PAS steering rack ratios | mattsrallye | 14 | 8,944 |
23-02-2017, 06:11 PM Last Post: Eeyore |
| Steering rack piston cover | doogle-d turbo | 2 | 2,925 |
10-07-2016, 04:19 PM Last Post: doogle-d turbo |
