T2 wastegate arm
Anybody any trick to get the waste gate arm of a T2 back onto the pin after screwing it? Seems to be a right nightmare!
I had a bit of a struggle years ago, included a pry bar and a smashed finger lol, easier to get a mbc
As said, just stick an MBC on it. Makes turning boost up so much easier.
As for getting the arm back on, if you pull it a little (from the actuator) you should be able to get it onto the wastegate pin.
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
Only trouble with not tightening the wastegate arm is you will probably get slight wastegate creep when running high boost pressures with an mbc
[Image: av5ym8.jpg]
Get a pair of mole grips around it and lever against the mole grips.
  welded wastegate help daveylennon93 16 9,443 31-07-2014, 04:44 PM
Last Post: Dum-Dum
  T2 wastegate pbell283 20 12,151 06-06-2014, 09:59 AM
Last Post: toseland
  Wastegate creep? ADV_93 3 3,540 14-09-2013, 04:15 PM
Last Post: ste91
