Threads: 4
Hi, my phase 1 xsi is completely standard for now ;-) but it sounds like the exhaust is blowing, especially from around the cat. I've had it up on the Ramps and can't feel/see any gases/sooty deposits. Does any one have any ideas? Thanks
Threads: 16
Car Model/Spec: 306 GTI 3.0 V6
Have you had a good old feel around exhaust joints etc whilst someone applies a little revs to feel it blow more if the hole is very small? Also check the tightening of nuts and bolts etc do this when its warmed up.
Threads: 26
Car Model/Spec: Peugeot 406 Coupe 3.0 V6
Given 15 thank(s) in 13 post(s)
The joins are really crap flange type with a gripping clamp. The whole lot is prone to rust and falling apart. If its leaking gas it's a pretty high chance a join is to blame. On an old gti6 of mine I cut the flanges out and welded straight pipe to one side, and made a sleeve fit for the other. Took a couple of hours and was a great exhaust there after.
