Exhaust blowing????? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: Exhaust blowing????? (/showthread.php?tid=25125) |
Exhaust blowing????? - Chrisjohnson120486 - 07-07-2014 Hi, my phase 1 xsi is completely standard for now ;-) but it sounds like the exhaust is blowing, especially from around the cat. I've had it up on the Ramps and can't feel/see any gases/sooty deposits. Does any one have any ideas? Thanks RE: Exhaust blowing????? - calibra306 - 22-08-2014 Have you had a good old feel around exhaust joints etc whilst someone applies a little revs to feel it blow more if the hole is very small? Also check the tightening of nuts and bolts etc do this when its warmed up. RE: Exhaust blowing????? - Pebbles167 - 22-08-2014 The joins are really crap flange type with a gripping clamp. The whole lot is prone to rust and falling apart. If its leaking gas it's a pretty high chance a join is to blame. On an old gti6 of mine I cut the flanges out and welded straight pipe to one side, and made a sleeve fit for the other. Took a couple of hours and was a great exhaust there after. |
