XUD aux setup change?
So looking at swapping my auxillary setup on my sedan.
Currently has phase 2 a/c setup and want to go for phase 1,
I can get hold of another pas pump, alternator, tensioner and bracket.
Is there anything else i need or any problems i will have?
E.g pas pump not clearing the a/c bracket on current sump?
Thanks in advance
The sump will need triming with a grinder as the lower brakets wont fit for the pas pump. Also you will need the braket that attaches directly to the block its diffrent to the ac one.
Why are you changing to a ph1 setup?
I did mine as I had both lying about and the aircon was broke. Seemed to free up some space in engine bay. Looked neater imo. Also have a phase one rad.
Pretty much same reason as bash, ph2 has stupid tensioner setup and my auto one needs replacing anyway. Just easier having phase win setup!
