XUD aux setup change? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: XUD aux setup change? (/showthread.php?tid=25747) |
XUD aux setup change? - DougalDT - 05-08-2014 So looking at swapping my auxillary setup on my sedan. Currently has phase 2 a/c setup and want to go for phase 1, I can get hold of another pas pump, alternator, tensioner and bracket. Is there anything else i need or any problems i will have? E.g pas pump not clearing the a/c bracket on current sump? Thanks in advance RE: XUD aux setup change? - bashbarnard - 05-08-2014 The sump will need triming with a grinder as the lower brakets wont fit for the pas pump. Also you will need the braket that attaches directly to the block its diffrent to the ac one. RE: XUD aux setup change? - dannyboy101 - 08-08-2014 Why are you changing to a ph1 setup? RE: XUD aux setup change? - bashbarnard - 08-08-2014 I did mine as I had both lying about and the aircon was broke. Seemed to free up some space in engine bay. Looked neater imo. Also have a phase one rad. RE: XUD aux setup change? - DougalDT - 08-08-2014 Pretty much same reason as bash, ph2 has stupid tensioner setup and my auto one needs replacing anyway. Just easier having phase win setup! |
