coolant flow
coolant flow
I'm getting to the point of being so tired I'm going mad...
Anyway...
I can't quite work out in my head which way the coolant flows through the oil/coolant heat exchanger plate...
From stat housing to rad or the other way round?
I would have said stat housing to rad? Yeah? Undecided
Anyone confirm this? Smile
I thought it went pump > rad > stat > etc
Well hot water enters the top of the rad...via the stat...so it must flow that way surely?
Yeah, it must go towards the rad...otherwise you're just putting hot water through hot oil which isn't gonna help anything...
flows from engine to cooler to rad when the stat is closed as it is used to heat the oil to operating temperature
when the stat opens
flows from engine to top rad hose and the flow through the cooler is slight as its more restrictive than the top hose
Pump - head - heater matrix - pump
when the stat opens..
pump - head - heater matrix - stat - radiator - pump
/Toseland
I think the 2.1 had a slightly different matrix return flow toseland.
Im basically trying to work out where to take a feed for the turbo coolant jacket. I need a supply and return
any thouhgts? I need coolish flow into turbo and then somewhere to dump the flow back into the system. Needs to be constant too, not reliant on stat opening etc
  Flow vs psi? Lwilliams 19 13,033 02-08-2020, 12:22 PM
Last Post: ekjdm14
  XUD9TE high flow oil pump on XUD7TE assembled 5 3,989 01-07-2015, 02:34 PM
Last Post: assembled
  High flow diesel filter MarkHam 5 3,467 15-07-2014, 08:14 PM
Last Post: zx_volcane
