01-08-2014, 12:35 PM
Found this 2day. Pretty common to go there anyway.
Be hard fixed?
Be hard fixed?
Big rust hole :(
Be hard fixed? HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
01-08-2014, 12:55 PM
I found mine quite hard to fix and time consuming with all the rust removing and making/shaping a new piece to go in. I hadn't welded before so took a little while to get the hang of it but in the end I was quite happy with the result
[attachment=18099]
01-08-2014, 12:58 PM
Good job for not havin welded b4 that.
I have a crashed 306 here was just goin to cut out the same piece out of that and weld it in. HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
01-08-2014, 01:06 PM
Thanks, it's not pretty but solid. That would make things easier as it'll save you messing around trying to shape it....providing your crashed 306 doesn't have rust there.
01-08-2014, 01:34 PM
My hatch was really.bad had to replace entire inner rear quarter. Have a look at my old project thread. A bit of patience and anything is possible. If you want go to scrappy find a good one and cut the section out you want. That way you know it fits
01-08-2014, 01:44 PM
No the crashed one is 100% rust free which is a 1st.
Pug really did f*ck up not puttin the wheel liner in the rear on the phase 1s. Yeah ill chek that proj thread out. Cheers HDI D'Turbo Daily Driver ---- XUD D'Turbo Project |
| Confirm a head hole for me. | bashbarnard | 10 | 5,706 |
26-02-2016, 07:55 PM Last Post: bashbarnard |
| Cambelt Change (timing hole alignment) | Mark | 30 | 25,297 |
09-07-2013, 05:24 PM Last Post: ADV_93 |
| Fair size hole in my gearbox casing!! | 306Brad | 21 | 12,682 |
26-06-2013, 03:32 PM Last Post: 306Brad |
