Threads: 93
8
Every time I say this it sounds like a joke, but I have an intermittent fault with my indicators. They just stop working whenever they fancy it, and appear now to have completely died.
They don't do any clicking, so am I to assume the relay is the likely culprit, or is it more likely to be the stalk, or something?
Cheers
![[Image: sigcopy-1.jpg]](http://i570.photobucket.com/albums/ss147/KEZZIEBOY/Diablo%20HDi/sigcopy-1.jpg)
Check the hazard light switch is plugged in properly.
Threads: 62
10
I had this, faulty relay. Lots of intermittent life followed by complete death.
HDi Owner for 200k/9 years
Pull the relay and take the case off, be pretty obvious if its worn.
Stalks can do this too mind. Both cheap and easy enough to replace mind
Threads: 93
8
I'll check the connection on the hazard switch first, then the relay I guess.
Cheers chaps!
