15-06-2014, 09:59 PM
what size T-piece is needed to fit a boost gauge?
6mm maybe?
where to source one?
6mm maybe?
Boost gauge T-piece
6mm maybe? where to source one?
15-06-2014, 10:33 PM
Yeah pretty sure its 6mm. Best to have a look on ebay
15-06-2014, 10:49 PM
Halfrauds sell em. Or, IIRC, the T piece from washer jet pipes fits. Grab one next time you're in the scrappy, maybe worth a check?
Phaes 1 GTI 6 - Onyx Black
19-06-2014, 01:54 PM
ebay they're 99p...
8mm for 99p: http://www.ebay.co.uk/itm/Tpiece-straigh...2c5e6afc83 4mm for £1.27: http://www.ebay.co.uk/itm/4MM-T-PIECE-HO...53f47537f9
21-06-2014, 12:27 AM
had this one in the end as i missed the other links *woopsy*
http://www.ebay.co.uk/itm/190885965346?_...EBIDX%3AIT 8mm--4mm--8mm fitted a treat!
21-06-2014, 07:10 PM
6-4-6 would be best, you should ideally be using 4mm id for the gauge hose anyhow
/Toseland
19-07-2014, 08:38 PM
Is using a t piece the easiest way on an xud or is there somewhere to drill and tap?
19-07-2014, 09:11 PM
T piece has to be the easiest way.
Takes 2 minutes to join t piece and run hose into car. HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
19-07-2014, 09:48 PM
Where to t into on these, i know on the hdi t-ing is a pig, but going to help fit a boost gauge on one of these soon.
19-07-2014, 10:44 PM
you ahve the intercooler, then the best way is to T into the line that runs from the intercooler to the boost compensator on the pump./
that is most common anyhow Given the choice between Niall and the sheep. I would choose the sheep!
/Toseland
20-07-2014, 11:19 PM
It depends what size hose your gauge takes really.
22-07-2014, 10:38 PM
29-07-2014, 04:37 PM
Make sure you get a T-piece with anti-flutter in it. Nothing more annoying than a boost gauge that shakes more than harlem
3 x Peugeot owner.
1996 106. 1996 306 D Turbo S. 1994 Mercedes Benz 320E. 1997 306 GLX. Subscribe! - https://www.youtube.com/user/TheADKJD/videos |
| Boost Gauge Decisions | CJRODELL | 7 | 4,685 |
22-12-2014, 10:16 PM Last Post: CJRODELL |
| Boost gauge help? | Ryan'dolan | 2 | 2,358 |
20-09-2014, 08:40 AM Last Post: Piggy |
| Where to T-piece | Nathan1305 | 9 | 5,831 |
15-08-2014, 12:52 PM Last Post: Danny2009 |
