Threads: 186
38
Car Model/Spec: MG ZR VVC
Given 21 thank(s) in 19 post(s)
Threads: 476
81
Car Model/Spec: 306 Rallye
Yeh dont take it to where I had my head skimmed....
Threads: 208
60
Given 5 thank(s) in 5 post(s)
#Dreamer???  lol
Threads: 186
38
(30-06-2014, 10:55 AM)SRowell Wrote: Yeh dont take it to where I had my head skimmed....
Where you take it?
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
(30-06-2014, 09:32 AM)puglove Wrote: #shouldofboughtagti6?????
#nopointhasthesameproblem
Threads: 208
60
Threads: 82
27
Just remember Jamie, your low mileage healthy 2.0 '6 pulled marginally more than a HGF'd 1.8 MG engine
Threads: 208
60
Nah dyno was wrong.
Threads: 82
27
Odd, rest of the figures seemed accurate.
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Good progress, just need to get it all back together now
Threads: 186
38
Head is in the shop for skimming, before leaving though I just checked they could do it with valves in the guy behind the counter checked and said some of the exhaust valves may need to come out so left a bag of new stem seals for any he takes out.
After a walk in the forrest with mum and the puppy which resulted in me finding a rope swing over a river and getting somewhat wet feet come home to clean up the carrier and check vvc timing
Carrier is much cleaner now but just need to read some guides on making sure the vvc timing is right, although from what I can remember it does seem pretty on the mark
Forgive the photo quality but the htc doesn't seem to like low light
Threads: 117
119
30-06-2014, 06:20 PM
(This post was last modified: 30-06-2014, 06:21 PM by Poodle.)
£50 skim and they didn't bother to clean it, tight bastards.  SMW?
Threads: 186
38
30-06-2014, 07:03 PM
(This post was last modified: 30-06-2014, 07:05 PM by lolsteve.)
SMW?
I haven't got the head back yet so it might be cleaned I don't know yet. Guy said it's been skimmed but not to death so that's good i guess
Spent the afternoon cleaning up the cam carriers, reading about the vvc timing and then checking the timing using this guide
http://www.davebence.co.uk/mods_10.htm
timing seems fine so reassembled the piston assembly and just waiting on the head + rover sealant
Also thinking about porting the exhaust ports as not sure if you can see in the photos above but there's a thick black ring around the exhaust ports which says to me there's some space for porting?
Threads: 541
124
Its largely pointless porting the ports unless your going to port the manifolds too. Also what are the standard ports like, enlarging them could drop gas velocity and loose you power especially mid range.
Threads: 96
7
Car Model/Spec: 306 tractor
30-06-2014, 08:23 PM
(This post was last modified: 30-06-2014, 08:27 PM by devils_fuel.)
Ha ha my original comment was pointless lol
Good job you've done it properly mate, it's the best way forward.
You may get some ponies back as I bet that HG had been seaping for a while, time the vvc up properly and you may be back on to as new bhp figures
Threads: 591
54
Yeah catchup DF. He getting it skimmed!!
Just try and decoke those ports matey
Threads: 186
38
Standard ports look pretty small with a huge black ring where there's difference between the port and gasket. The new manifold should be larger as well since it doesn't have horrific internal welds like the standard rover one did
I think it's been leaking for some time since there was no shim which acts to protect the head and has a "heat activated bonding agent" which no doubt helps fill some gaps. So with a non leaking head it's time to beat some 6's
VVC seems timed up alright as I've never done it before I can only hope i did it right and don't find its jammed or whatever when it's back on the car
decoke with an italian tune up thats not burning coolant/oil?
Threads: 117
119
Mr muscle again mate.  There needs to be a difference between the port and mani bore size, helps scavenge and prevents back-flow.
Threads: 186
38
Fair enough don't really understands the mechanics of the port/manifold bore sizes just looked it was another rover thing where they didn't do the job properly
£1 oven cleaner any good?
Threads: 465
114
Car Model/Spec: Vauxhall
Threads: 91
83
Essentially - unless you really know what you're doing with cylinder heads, getting friendly with the dremel usually ends in making either no difference or making it worse.
I've read and read about it, still I wouldn't take a dremel to my own NA Petrol cylinder head, you're likely to do more harm than good!
Threads: 151
14
Car Model/Spec: 306 D-turbo
I've heard if you poar some Sand down inlet it will port it out lovely
Serious note I'm with Ruan unless you know what your doing I wouldn't touch it
Team Doesn't own a 306
Threads: 186
38
Fair enough, I'll leave it be.
Head is back from the shop, valves needed to be removed apparently so in total it's cost me £95 for a skim and new stem seals (which I supplied) bit f*ked off as I would have removed the valves myself if I knew it would be an extra 45 quid thought it would be about £20
Threads: 541
124
(01-07-2014, 02:41 PM)Ruan Wrote: Essentially - unless you really know what you're doing with cylinder heads, getting friendly with the dremel usually ends in making either no difference or making it worse.
I've read and read about it, still I wouldn't take a dremel to my own NA Petrol cylinder head, you're likely to do more harm than good! TBH these days I probably wouldn't trust anyone doing it by hand. CNC head porting is the way forward every time as the results are entirely repeatable and with computer modelling you can see exactly what the flow will be like under any given circumstances.
Threads: 8
1
Car Model/Spec: 405 SRDT
Given 6 thank(s) in 6 post(s)
(01-07-2014, 05:48 PM)Dum-Dum Wrote: (01-07-2014, 02:41 PM)Ruan Wrote: Essentially - unless you really know what you're doing with cylinder heads, getting friendly with the dremel usually ends in making either no difference or making it worse.
That's the pioneering spirit that got this country where it used to be summed up right there lol. :p
Threads: 186
38
Quick question before I put the head all back together tomorrow. Been looking at the guides some more and it talks about refurbishing the tappets by hitting them against a block of wood to get the pistons out for a clean etc but at the end of the guides it talks about rubbing the top surface against sandpaper to rough up the contact face.
What good will this do? Just thinking about it now since I have some time before needing to put this together so would be better to do now rather than later
Threads: 106
7
Car Model/Spec: GTi-6
Were the tappets rattling before? If not - I wouldn't bother. Can potentially give yourself another unwanted bill.
If they WERE rattling however, worth getting them apart and getting all the gunky jelly oil out of them, clean them up and pop them back in.
I wouldn't rough them up either, otherwise you'll have to (in an ideal world) do another cam bed in procedure. Just make sure you put the right tappet back in to the right hole!
JP
JP
Threads: 186
38
They had the normal k series tappet sound, I suppose some lifter cleaner could be put in afterwards if do feel they're a bit noisy
12/16 tappets I know where put back correctly, the last 4 may have got slightly muddled up or might be in the right order. Doesn't help with the markings come off
Next question in regards to the carbon on the piston crown. Went back out this morning to check the engine is still in one piece etc and noticed some of the carbon deposits have gone soft, tried to wipe up some of the moisture and ended up pushing some of the carbon into the corners . Is this something that will just get burnt off and sucked out the exhaust or will it scratch apart the liners and get stuck in the piston ring  Wish I hadn't touched it now
Threads: 117
119
Be fine if its gone soft mate.
Threads: 120
35
Car Model/Spec: Rallye/S16 & 175 megane
Given 40 thank(s) in 40 post(s)
Will just burn up and exit through valve  jobs going well steve fair play dude
![[Image: 17b33c2a-8471-4313-992e-0a4b324cf926_zps2e63812a.jpg]](http://i143.photobucket.com/albums/r143/matt-taylor/17b33c2a-8471-4313-992e-0a4b324cf926_zps2e63812a.jpg)
Team Cyril
