xud9te super economy set up?
That is what I am interested in...anyone know how?
Though I am a fan of Darren j Lobb`s XUD handiwork!
1) Fit a bosch pump
2) do a mild stage1 tune
3) run on veg oil for 50-75% of the cost of diesel
Smile
Is there a way without veg oil, just using pump diesel, I figure that the amazing increase in power by relatively small adjustments to fuelling boost etc to the XUD9TE would suggest that economy (though not a popular thread) could also be tweaked in some way, I am a full on newbie mind!
Its known that a stg1 tune will improve economy.
You could reduce fueling a bit...but you may find the need to boost more to get going!!
GT15 or newer if you can.
VE pump.
Tweak Injection quantity a little for improved torque.
Play with timing until best results are achieved.
Went from the original T2/K14 and ~45mpg to a GT15 which gave low 50s to the GT20v and instantly was up to 58mpg on a run - amazing the efficiency gains from modern turbochargers.
I'd be interested in an economy setup too doing 100+ miles a day to work and back.
Are the GT15/GT20v direct fits ?
Gt15 is, gt20 isn't
So what vehicle would I find the GT15 on ?
Very late XUD9s - Generally on a T plate.
What Ruan said, aside from making sure your running a bosch pump with good injectors / timing, the best thing that will effect your MPG is the turbo....
You wouldnt believe how far turbo technology has come fowards since the old T series....They can move air so efficiently now its unreal...
[Image: sigi-2.png]
My car is on a T plate, so does that mean I might have the GT15 already ?
Just need to sort out a Bosch pump setup now...
Ive got a gt15 you can have. Ive recently blown it up though
for infinite mpg, leave your car at home and walk or cycle
/Toseland
(30-06-2014, 04:13 PM)toseland Wrote: for infinite mpg, leave your car at home and walk or cycle
I would, if I didn't work 55 miles from home !
then bosch, stage1 and veg = the winning combo..
/Toseland
  Tuning for economy DavidA 11 5,863 07-05-2014, 05:22 PM
Last Post: Mattcheese31
  De-tuning a xud for economy? Andy annear 18 7,623 20-03-2014, 07:24 PM
Last Post: Tom
  Fuel economy tips WiNgNuTz 30 15,013 04-10-2013, 12:01 PM
Last Post: silverzx
