Fuel Filter Replacement
How often should i be changing mine?
Every 12k I think. Unless your running on veg oil, then do it a few times in the first 2000 miles and then probably every 10k.
They are only £3 from ECP, and it can never hurt to do it more frequently Smile
Captain Standard
Mine gets done every 6-8k with the rest of the filters and oil.
Its so cheap to do that you'd be silly not to do it a few times a year.
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
I do mine every 2 or 3 oil changes, with a pump you're spinning faster than normal and is injecting more than stock, you don't want any restriction on the inlet... You're likely to drain the pump body and cause damage, it's like running an engine at full speed and running it out of oil...
Yeah theyre not expensive and easy to change so why not?
Where is ECP? lol I need to change mine!
306 HDI, soon to be XUD
declantg Wrote:Where is ECP? lol I need to change mine!
http://www.eurocarparts.com/store-locator ninja
Captain Standard
thank you!
Rep? ninja
declantg Wrote:thank you!
Rep? ninja
I do not know of this Rep you speak of.. :geek:
Captain Standard
  Filter housing replacement weka 2 3,122 25-08-2017, 06:16 PM
Last Post: weka
Exclamation Swarf In Fuel Filter Housing jordanhdi 11 6,165 26-09-2016, 11:55 AM
Last Post: pug306driver
  Removing the fuel filter housing, but what is this behind it? Iaitoo 2 3,111 27-04-2016, 05:33 PM
Last Post: Iaitoo
