21-05-2014, 10:33 AM
Ok so i fitted my turbo now it sounds bit like a police siroen with no boost but the reek is pure black not a bit of white could it be a boost leak ?
Fitting turbo
21-05-2014, 12:52 PM
sounds like it.. all gaskets new on the inlet/pipes? it would have to be a pretty hefty boost leak break out the soapy water and give all the pipe joints a spray, rev the engine gently, if yous ee bubbles you have a leak..
i would suspect that something is open completely or left off somewhere however Given the choice between Niall and the sheep. I would choose the sheep!
/Toseland
21-05-2014, 02:52 PM
Didnt change any gaskets
21-05-2014, 02:58 PM
Lol
Have you got a boost gauge to see what it's boosting? Is there any play in turbo? Let's hope inlet/exhaust gasket isn't leaking or you will have to take turbo off again
21-05-2014, 02:59 PM
No play in turbo and hope not like and boosting 0 psi
21-05-2014, 04:42 PM
If there is 0 psi something's not right even a blowing gasket still should register some boost made sure the boost gauge pipe is on properly or if it's split
21-05-2014, 05:01 PM
Tryed everything think needs another turbo
21-05-2014, 05:11 PM
Have you connected the pipes properly? Lol
21-05-2014, 05:19 PM
Yea u have
21-05-2014, 06:38 PM
Ok the turbo im gettingg is a k14 has manafold and all the pipes still
hopefully goes straight on
| Fitting bigger turbo shortly | Owen_G_ | 16 | 9,914 |
07-03-2015, 11:25 PM Last Post: Piggy |
| D turbo downpipe fitting kit | philpemberton94 | 8 | 5,387 |
12-03-2014, 06:27 PM Last Post: Tom |
