Threads: 374
38
Car Model/Spec: GTI 6
Large black relay on the right. Any idea what this relay is?
Has tendencies to click repeatedly when diriving, then stop, then start again.
New indicator stalk time!
Threads: 374
38
(14-05-2014, 04:17 PM)Niall Wrote: New indicator stalk time!
Oh really ..... /sigh
Why / how do you know this?
There's no actually fault at the moment, indicators have never been an issue at all
Threads: 142
58
Car Model/Spec: E46 BMW 320d
Not sure about the black relay, indicator relay would be the orange one iirc, and from your description i'd say it sounds like the indicator stalk as well. I refurbed mine in the DT, took me about 20 minutes start to finish, never had any issue with it again in the year or so afterwards.
Threads: 374
38
(14-05-2014, 04:45 PM)WiNgNuTz Wrote: Not sure about the black relay, indicator relay would be the orange one iirc, and from your description i'd say it sounds like the indicator stalk as well. I refurbed mine in the DT, took me about 20 minutes start to finish, never had any issue with it again in the year or so afterwards.
refurb the stalk?
Isn't it easier to just replace it?
Threads: 169
91
You can get them from about 8 quid on the bay.
Had the same issue with my car. Stalk fixed it.
Threads: 374
38
14-05-2014, 05:29 PM
(This post was last modified: 14-05-2014, 05:29 PM by ginge191.)
do they differ at all between models/phases?
Threads: 87
48
(14-05-2014, 05:29 PM)ginge191 Wrote: do they differ at all between models/phases?
don't think so mate . .
Threads: 142
58
I was unemployed and skint at the time, seemed a better idea to try and fix what i already had.
Threads: 169
91
14-05-2014, 05:33 PM
(This post was last modified: 14-05-2014, 05:33 PM by Grant.)
(14-05-2014, 05:29 PM)Mattcheese31 Wrote: (14-05-2014, 05:29 PM)ginge191 Wrote: do they differ at all between models/phases?
Yes. Some cars will not have front fogs switch. Others will.
Also, some Ph1 had a round horn button, Ph2 and 3 have an oval type.
Threads: 374
38
(14-05-2014, 05:33 PM)Grant Wrote: (14-05-2014, 05:29 PM)Mattcheese31 Wrote: (14-05-2014, 05:29 PM)ginge191 Wrote: do they differ at all between models/phases?
gotcha; and the Partner vans share these also, right?
Threads: 169
91
No. The partner van has the same type as the 206. This could be multiplex depending on the age. Either way, it won't fit.
Threads: 374
38
(14-05-2014, 05:35 PM)Grant Wrote: No. The partner van has the same type as the 206. This could be multiplex depending on the age. Either way, it won't fit.
right on... i'll get to the scrappy at the weekend then!
Threads: 371
29
Car Model/Spec: ford fiesta
Revival!!! Im having this issue atm. Just repeatdly clicking then stops anytime I go to look at it. Is this a really common thing?
18-06-2014, 08:24 AM
(This post was last modified: 18-06-2014, 08:27 AM by Toms306.)
Yep, the indicator stalks are a pretty common fail.....not so bad at the early 'annoying' stage but if left can cause smoke from the dash!
Also, just FYI, indicator is small black or grey one, large orange one is for the rear heated window.
Threads: 374
38
Mine actually fixed itself... God knows what happened; but similarly the wiper motor which was playing up also sorted itself out.
Threads: 371
29
Might just replace the stalk to be safe. You got one tom??
Threads: 142
58
81
mine has started to do this as well. Clicks lots if the stalk is slightly up or down of its normal central position.
Threads: 27
Car Model/Spec: Ph1 xrdt
I think I have an indicator stalk if needed
(18-06-2014, 09:55 AM)bashbarnard Wrote: Might just replace the stalk to be safe. You got one tom??
Don't have any known good ones....sold 3 in a month lol, as said they're a common problem!
I do have a non-fog one that I bought years ago in error (sellers error!) if I can find it you can have it, never tried it though.
Threads: 183
20
Given 8 thank(s) in 8 post(s)
(18-06-2014, 12:44 PM)bimmerfix88 Wrote: *Staff edit - spam removed*
Sorry this is 306oc not bummersoc.co.uk.
This strange this pops up, ive never once had this problem in all my 306s. But deggs has this in his and its first ive ever heard off, now mine does it as well in the '6. Also crumps has started doing it, now its all over here
Ive just been scrap yard and picked a couple stalks up.
Threads: 371
29
I feel like ill hit up.the scrappy and get sone front fogs on mine at same time. Kill two birds in one stone and all that
18-06-2014, 03:19 PM
(This post was last modified: 18-06-2014, 03:21 PM by Toms306.)
Yeah might as well....set of crystals as well if you don't already have those lol.
(18-06-2014, 12:47 PM)kentiiboii Wrote: (18-06-2014, 12:44 PM)bimmerfix88 Wrote: *Staff edit - spam removed*
Nah its been happening a long while, my 1st 1.8 did it badly (to the point of smoking lol) and that was about 4 years ago now!
Threads: 183
20
None of mine have ever done it, only my '6.
