Clicky relay; pics.. - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: Clicky relay; pics.. (/showthread.php?tid=24044) |
Clicky relay; pics.. - ginge191 - 14-05-2014 Large black relay on the right. Any idea what this relay is? Has tendencies to click repeatedly when diriving, then stop, then start again.
RE: Clicky relay; pics.. - Niall - 14-05-2014 New indicator stalk time! RE: Clicky relay; pics.. - ginge191 - 14-05-2014 (14-05-2014, 04:17 PM)Niall Wrote: New indicator stalk time! Oh really ..... /sigh Why / how do you know this? There's no actually fault at the moment, indicators have never been an issue at all RE: Clicky relay; pics.. - WiNgNuTz - 14-05-2014 Not sure about the black relay, indicator relay would be the orange one iirc, and from your description i'd say it sounds like the indicator stalk as well. I refurbed mine in the DT, took me about 20 minutes start to finish, never had any issue with it again in the year or so afterwards.
RE: Clicky relay; pics.. - ginge191 - 14-05-2014 (14-05-2014, 04:45 PM)WiNgNuTz Wrote: Not sure about the black relay, indicator relay would be the orange one iirc, and from your description i'd say it sounds like the indicator stalk as well. I refurbed mine in the DT, took me about 20 minutes start to finish, never had any issue with it again in the year or so afterwards. refurb the stalk? Isn't it easier to just replace it? RE: Clicky relay; pics.. - Grant - 14-05-2014 You can get them from about 8 quid on the bay. Had the same issue with my car. Stalk fixed it. RE: Clicky relay; pics.. - ginge191 - 14-05-2014 do they differ at all between models/phases? RE: Clicky relay; pics.. - Mattcheese31 - 14-05-2014 (14-05-2014, 05:29 PM)ginge191 Wrote: do they differ at all between models/phases? don't think so mate . .
RE: Clicky relay; pics.. - WiNgNuTz - 14-05-2014 I was unemployed and skint at the time, seemed a better idea to try and fix what i already had.
RE: Clicky relay; pics.. - Grant - 14-05-2014 (14-05-2014, 05:29 PM)Mattcheese31 Wrote:(14-05-2014, 05:29 PM)ginge191 Wrote: do they differ at all between models/phases? Yes. Some cars will not have front fogs switch. Others will. Also, some Ph1 had a round horn button, Ph2 and 3 have an oval type. RE: Clicky relay; pics.. - ginge191 - 14-05-2014 (14-05-2014, 05:33 PM)Grant Wrote:(14-05-2014, 05:29 PM)Mattcheese31 Wrote:(14-05-2014, 05:29 PM)ginge191 Wrote: do they differ at all between models/phases? gotcha; and the Partner vans share these also, right? RE: Clicky relay; pics.. - Grant - 14-05-2014 No. The partner van has the same type as the 206. This could be multiplex depending on the age. Either way, it won't fit. RE: Clicky relay; pics.. - ginge191 - 14-05-2014 (14-05-2014, 05:35 PM)Grant Wrote: No. The partner van has the same type as the 206. This could be multiplex depending on the age. Either way, it won't fit. right on... i'll get to the scrappy at the weekend then! RE: Clicky relay; pics.. - bashbarnard - 18-06-2014 Revival!!! Im having this issue atm. Just repeatdly clicking then stops anytime I go to look at it. Is this a really common thing? RE: Clicky relay; pics.. - Toms306 - 18-06-2014 Yep, the indicator stalks are a pretty common fail.....not so bad at the early 'annoying' stage but if left can cause smoke from the dash! ![]() (14-05-2014, 04:45 PM)WiNgNuTz Wrote: Not sure about the black relay, indicator relay would be the orange one iirc Also, just FYI, indicator is small black or grey one, large orange one is for the rear heated window.
RE: Clicky relay; pics.. - ginge191 - 18-06-2014 Mine actually fixed itself... God knows what happened; but similarly the wiper motor which was playing up also sorted itself out. RE: Clicky relay; pics.. - bashbarnard - 18-06-2014 Might just replace the stalk to be safe. You got one tom?? Re: RE: Clicky relay; pics.. - WiNgNuTz - 18-06-2014 (18-06-2014, 08:24 AM)Toms306 Wrote: Yep, the indicator stalks are a pretty common fail.....not so bad at the early 'annoying' stage but if left can cause smoke from the dash! Fair enough, obviously I don't recall correctly then!
RE: Clicky relay; pics.. - Eeyore - 18-06-2014 mine has started to do this as well. Clicks lots if the stalk is slightly up or down of its normal central position. RE: Clicky relay; pics.. - nick000 - 18-06-2014 I think I have an indicator stalk if needed RE: Clicky relay; pics.. - Toms306 - 18-06-2014 (18-06-2014, 09:55 AM)bashbarnard Wrote: Might just replace the stalk to be safe. You got one tom?? Don't have any known good ones....sold 3 in a month lol, as said they're a common problem! I do have a non-fog one that I bought years ago in error (sellers error!) if I can find it you can have it, never tried it though. Re: - kentiiboii - 18-06-2014 (18-06-2014, 12:44 PM)bimmerfix88 Wrote: *Staff edit - spam removed* Sorry this is 306oc not bummersoc.co.uk. This strange this pops up, ive never once had this problem in all my 306s. But deggs has this in his and its first ive ever heard off, now mine does it as well in the '6. Also crumps has started doing it, now its all over here Ive just been scrap yard and picked a couple stalks up. RE: Clicky relay; pics.. - bashbarnard - 18-06-2014 I feel like ill hit up.the scrappy and get sone front fogs on mine at same time. Kill two birds in one stone and all that
RE: Clicky relay; pics.. - Toms306 - 18-06-2014 Yeah might as well....set of crystals as well if you don't already have those lol. (18-06-2014, 12:47 PM)kentiiboii Wrote:(18-06-2014, 12:44 PM)bimmerfix88 Wrote: *Staff edit - spam removed* Nah its been happening a long while, my 1st 1.8 did it badly (to the point of smoking lol) and that was about 4 years ago now!
Re: Clicky relay; pics.. - kentiiboii - 18-06-2014 None of mine have ever done it, only my '6. |
