Fitting Front ARB
When I bought my VTS beam, I also managed to get the front ARB too (as well as shocks etc). I'd like to fit this but need to clear something up.....As I understand the subframe can be dropped a touch without completely removing it. I'd imagine the lower engine mounting will have to be disconnected from the subframe, but what about the steering column?
The HDi has a rebuilt and lowered VTS beam already fitted, with B4 VTS shocks, refurbed calipers and new Lemforder mounts. Front is getting B4 VTS shocks, VTS springs, new SKF VTS top mounts, Lemforder droplinks/TREs/BJs and the VTS front ARB. Should be sweet when finished, shame my spare VTS 2.6 rack has the wrong pipe connections or I'd chuck that on too.
Just undo the bolt through the lower mount then drop the subframe down an inch. Job done. The column won't cause you any issues.
Don't forget if its a bigger ARB, you will need different ARB mounts. Smile
(10-05-2014, 10:20 AM)Niall Wrote: Just undo the bolt through the lower mount then drop the subframe down an inch. Job done. The column won't cause you any issues.
Not too difficult then....yep, got the ARB clamps with the ARB.
Clamps are the same mate. Its the rubbers you need Smile. Only about £10 for them
Niall when you say this do you literally mean the rubber mounts or the sort of D shaped metal that clamps it? . . . . reason i ask is that i've got a GTI6 front ARB to go on the Dtub complete with the rubber mounts, this will fit in fine without anything else i'm hoping . .Smile
The rubber mounts mate. The 'D' brackets are the same throughout the models i believe but the rubbers have a bigger centre bore to take the bigger ARB. As i said mate, they are only about £10 from ECP but double check you get the right size. When i did the ones on my 1.8, i got given 18mm ones which came up under my reg even though it had GTI suspension from the factory. In the end, i just got them to search manually for them Smile
cheers, i've heard different things from different people but i'm sure you're right . .Smile
Don't bother, it wont improve it, and its probably the same size anyway!
(10-05-2014, 11:13 AM)welshpug Wrote: Don't bother, it wont improve it, and its probably the same size anyway!
well surely it will lessen body roll, are you saying you think Dtub has same ARB as GTI then?
(10-05-2014, 10:43 AM)Niall Wrote: The rubber mounts mate.
Got those as well, but for the cost of £9 from NeatAutos I ordered a new OE pair.
it'll be the same size most likely.
if it is smaller that's a good thing on a fwd car, more front end grip.
(10-05-2014, 01:48 PM)welshpug Wrote: it'll be the same size most likely.
then why would they spec them on the GTI6? . . .Smile
my understanding was it transfers upward force from the outside wheel into downward force on the inside wheel, increasing grip. a bigger bar has less flex and so transfers more force?
correct me if im wrong, but thats just what ive learnt.
transfers upward motion of the outer wheel ACROSS the car, where it tries to lift up the inner wheel into the wheel arch---effectively tries to tip the front of the car towards the inner wheel.
(10-05-2014, 02:19 PM)Mattcheese31 Wrote: then why would they spec them on the GTI6? . . .Smile
'Cause it feels better to the unwashed masses if it doesn't lean so much, but they don't want to screw the spring rates up. Stiffer = must be a racecar.
There was no front arb on mine Wink
(10-05-2014, 05:40 PM)PE02KHG Wrote: my understanding was it transfers upward force from the outside wheel into downward force on the inside wheel, increasing grip.
No, it transfers upwards force in the outside wheel, into upwards force on the inside wheel.
why did Citroen go stiffer on the rear springs and a faster steering rack? Wink
... to make more of their cars donor'able into a better looking Peugeot than just the engine? :p
  fitting a front suspension ball joint impotentials 3 3,844 29-10-2016, 05:46 PM
Last Post: Poodle
  front strut brace fitting titch 6 5,302 03-03-2013, 02:19 PM
Last Post: titch
