Diablo lacquer peel
Diablo lacquer peel
Is there any way to repair it? Does fine sanding down and re lacquer do the trick? Thanks in advance.
You can drop a bit of lacquer on it to seal it other than that its a paint job
As above. Blending it will be near on impossible. It's a panel respray job unfortunately
  Lacquer peel Magenta Sunset 2 2,652 30-05-2017, 04:43 PM
Last Post: Magenta Sunset
  headlamp peel rampaginrabbuts 5 3,556 24-09-2016, 05:37 PM
Last Post: P-Courty
  Lacquer peel : can you actually prevent it? ozonehostile 28 17,667 10-01-2014, 01:16 PM
Last Post: ozonehostile
