Wanted: Rear brake compensator valve thingy...
I had a ph1 xsi that I had the disc axle off and that didn't have a compensator
#32
That would have had inline pressure limiters on the boot floor if it was non abs, or a proper load compensator with ABS.
#33
I dont have abs ninja
you will need some form of rear brake pressure limiting, unless you like stopping backwards.
#35
I have never had issues, 10k miles of motoring
Just look at a MOT brake test, there just isnt that much brake effort that goes through back wheels
I have never seen an MOT tester perform an emergency stop on the rollers. only progressive braking on MOT's
Team Cyril
#37
(25-04-2014, 10:01 PM)Piggy Wrote: I have never had issues, 10k miles of motoring
i did 30-40k and only had a problem once . . . once is enough, just be told will you ffs . .lol
#38
The way mine brakes is scary tbh, makes it twitchy and not nice, no confidence in harsh braking whatsoever.
Team Cyril
#39
Sounds like you got other issues matt...
(26-04-2014, 10:59 AM)Piggy Wrote: Sounds like you got other issues matt...
other than you none whatsoever . . . . . Wink x
Sad rear brake compensator hycraig 0 2,360 26-03-2019, 07:57 PM
Last Post: hycraig
  Wanted: Gear selector thingy Chris_90 3 3,792 02-03-2017, 10:18 PM
Last Post: kentiiboii
Rainbow Wanted: Rear back brake disc shield covers Welshy_Pete 3 3,879 19-10-2016, 10:53 AM
