amp power cable route
where the best place to route the amp power cable through the bulkhead ???
do i need to drill a hole ???
if you don't have aircon then you can drill a hole behind the top glove box.
there is a couple of grommets that you might be able to find
I drilled a hole down the bottom, pull back the carpets, trim the sound deadening, and there is a heater matrix pipe there, I drilled just to the left of the pipe
I was going to ask this too, mine is running through the door atm..
When I removed my engine i removed my aircon, and the pipes went through the bulkhead in a square grommet. I poked a long rod into the grommet/void and could hear tapping. I looked in the passenger footwell and look behind the fan motor to find a black box coming from the bulkhead and could gather that this was a 'trunking' of some sort?
Could someone back me up on this theory? As I dont want to go drilling a hole there and the drilling through something important!
Mine runs under the car in cable armour. There's loads of grommets in the boot to run it through and cable armour is only 4 quid for 10m from screwfix. Job done!
Splendid idea!!!
[Image: 20120110_141823-1-1-1.jpg]
under the car FTW!
Neil Wrote:Mine runs under the car in cable armour. There's loads of grommets in the boot to run it through and cable armour is only 4 quid for 10m from screwfix. Job done!
Linky?
[Image: Signature.jpg]
http://www.screwfix.com/p/tower-corruga ... -10m/50443
I still think that running it under the car is incredibly pikey :/
SRowell Wrote:I still think that running it under the car is incredibly pikey :/
how so?
What like all the cabling that Peugeot ran under there. There's less chance of it chafing on sharp body parts, less chance of it snagging and less chance of it interfearing with your RCA leads. And it's easier to install! Win!
how so?
cause he didnt think of it Wink
Think it's only something that clever people would come up with cully! Lol
Pretty much. Im sure its fine in reality but every time i look around when im driving in liverpool there are tv cables running across roofs and into windows for tvs and i just think that cant be good! lol
Neil Wrote:http://www.screwfix.com/p/tower-corrugat...-10m/50443
Cheers Niall Smile
Why did i never have that idea!?!? Fair play to you sir, although i just found a rubber grommet to poke a hole through, then ran the power down the drivers side of the car, RCA and remote run down passenger side. Big Grin
Fuel lines are under there so why not
[Image: SDC10442-1.jpg]
How you attaching it to the underside?
4WayDiablo Wrote:How you attaching it to the underside?
Gotta be cable ties... gotta keep with the pug spirit surely? lol
Cable ties to the original wiring mounts FTW! It's a bit of a PITA keeping it out of the way of the ARB but cable ties help!
sweet, might go for this idea, as im lazy lol
cable tied mine to the brake pipe lines
I had thought of under the car but didn't do anything about it as I've not got a jack to look under under the car for routing so just dispelled it...cheers fellas :thumbup:
[Image: siggy1.jpg]
  Amp Power Cable - Hole? bigcheez2k3 6 5,760 30-11-2012, 01:01 AM
Last Post: Kwik
