Threads: 162
21
Given 23 thank(s) in 23 post(s)
Hi,
I was wondering if any off you lot had any experience with Borg and Beck clutches?
I found there is one fitted to the estate today and I was wondering if they're any good?
Threads: 465
114
Car Model/Spec: Vauxhall
Borg and Beck a few years ago were an excelent name dont know about recent years though
Threads: 57
3
Car Model/Spec: 306 s16 406 v6 Saab 93 Ttid
Given 3 thank(s) in 3 post(s)
As said always used to be good
Id have no issues driving a car with one fitted
Threads: 26
4
Given 6 thank(s) in 6 post(s)
Yea borg and beck is good, have been using there brake pads lately and there dead on.
Threads: 162
21
19-04-2014, 07:55 PM
(This post was last modified: 19-04-2014, 07:59 PM by DeeTurbo.)
Awesome thanks guys, I'll leave it in then.
I did feel it was a bit juddery but I think that might have been more to do with the loose top mount then the clutch now.
I was having difficulty getting the cover plate off as some monkey had over tightened the torx screw.
The clutch was starting to get heavy but I've found the cable to be damaged and the release bearing wasn't sliding every well because something was gumming up the way it slides across the input shaft tube.
Going to clean that up tomorrow, put some new fork bushes and a new cable to see if that makes it feel any better.
Threads: 386
87
New fork bushes will make a huge difference! I couldn't change them on the china, and the clutch is still a bit crap. Changed them on the moonstone and soooo much smoother lol!
The fork/arm pin is a right bugger to get out of the BE4 box though!
Threads: 541
124
part of the same company as First Line who do cables and suspension bits ad i like the first line stuff.
Obviously it aint gonna be as good as a Valeo but you get what you pay for
Threads: 162
21
(19-04-2014, 08:32 PM)Toms306 Wrote: New fork bushes will make a huge difference! I couldn't change them on the china, and the clutch is still a bit crap. Changed them on the moonstone and soooo much smoother lol!
Not if you have a m7x1 pitch nut it isn't!
I ordered some m7 nut of ebay but the bastards turned out the be the wrong pitch thread, luckily I had the right tap at work so tapped a m6 nut to the right size and made a puller out of a spacer with that nut.
(19-04-2014, 08:47 PM)Dum-Dum Wrote: part of the same company as First Line who do cables and suspension bits ad i like the first line stuff.
Did a search earlier and found them on ebay for around £200!
Threads: 541
124
Try euro car parts with club discount for a Valeo clutch, brings it in just under £100 IIRC
Threads: 386
87
(19-04-2014, 09:35 PM)DeeTurbo Wrote: (19-04-2014, 08:32 PM)Toms306 Wrote: New fork bushes will make a huge difference! I couldn't change them on the china, and the clutch is still a bit crap. Changed them on the moonstone and soooo much smoother lol!
Tried this, stripped the threads on 2 different 'boxes!
So this time left it soaking in plusgas overnight, then used mole grips and smacked them backwards with a lump hammer. Still took a lot of effort compared to the 1.8's BE3 arm pin!
Threads: 91
83
(19-04-2014, 10:39 PM)Toms306 Wrote: (19-04-2014, 09:35 PM)DeeTurbo Wrote: (19-04-2014, 08:32 PM)Toms306 Wrote: New fork bushes will make a huge difference! I couldn't change them on the china, and the clutch is still a bit crap. Changed them on the moonstone and soooo much smoother lol!
TRUST me they've gotta be easier!!!!
If the pin is easy in and out, fine, when that arm siezes, it's a total whore, had to get the burning bottles on mine and wreck basically new fork bushes due to the heat. And even then it was a total arsefuckwit.
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Borg & Beck supply oem clutches for some manufactures, fit with confidence as should be more than up to spec
Threads: 91
Car Model/Spec: stage1+ HDI
Given 1 thank(s) in 1 post(s)
Bringing back a old thread. Would that clutch hold limited torque stage2?
Threads: 371
29
Car Model/Spec: ford fiesta
(14-04-2016, 10:00 PM)tysonbully2k12 Wrote: Bringing back a old thread. Would that clutch hold limited torque stage2?
limited torque a standard valeo should hold. if you want a bit more but dont want to arse about with paddle a berlingo one is better i think
Threads: 61
3
Car Model/Spec: Phase 1 306 xsS
Given 21 thank(s) in 21 post(s)
14-04-2016, 10:18 PM
(This post was last modified: 14-04-2016, 10:19 PM by Redordead89.)
Borg n beck all good! Go for it!
(14-04-2016, 10:17 PM)bashbarnard Wrote: (14-04-2016, 10:00 PM)tysonbully2k12 Wrote: Bringing back a old thread. Would that clutch hold limited torque stage2?
Hey Tom, any joy with Lu's cars?
Threads: 91
2
Car Model/Spec: BMW 330Ci/VW Up/205GTi/205Mi16
Given 5 thank(s) in 5 post(s)
I've got the Sachs Berlingo on mine, but I'm sure it's now advertised for a standard 306 HDi too. No better than a new Valeo or similar as far as I know.
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
Threads: 82
27
15-04-2016, 09:01 AM
(This post was last modified: 15-04-2016, 09:01 AM by Midnightclub.)
Our valeo is still holding on (3/4 years?), no signs of slippage - full fat stage 2.
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
(15-04-2016, 09:01 AM)Midnightclub Wrote: Our valeo is still holding on (3/4 years?), no signs of slippage - full fat stage 2.
Genuinely don't know how that is possible dude haha!
Threads: 82
27
15-04-2016, 03:28 PM
(This post was last modified: 15-04-2016, 03:28 PM by Midnightclub.)
(15-04-2016, 02:53 PM)silverzx Wrote: (15-04-2016, 09:01 AM)Midnightclub Wrote: Our valeo is still holding on (3/4 years?), no signs of slippage - full fat stage 2.
Me to, haha!
Threads: 21
3
Car Model/Spec: Stage 3 HDi
Given 5 thank(s) in 4 post(s)
Because the car isn't making full power
Threads: 82
27
15-04-2016, 03:50 PM
(This post was last modified: 15-04-2016, 03:50 PM by Midnightclub.)
It wasn't for around 3k? New MAF, boost leak fixed and it is again. Been S2 for well over 40k now, been on the full fat map for about 36k
